Re: Use a forstner bit...
Fred Davis
>Grant's post about using Forstner bits is fine as far as it goes , but a good grade of Forstner is costly and in difficult woods like Osage Orange will have the same problem your Chisel bit is having, namely it can't get rid of the heat fast enough and will turn blue on you and ruin the bit.
I have done so many MT joints, that I really don't think about the process , but here is what I do.
Layout out the Mortise accurately , using a Machine spur bit, often called a Brad point bit, I would chuck a 3/8ths bit for hogging out the waste in a half inch wide mortise.
There are a couple of tricks to getting smooth absolutely vertical holes for both ends of the Mortise.
Being right handed I cut the first hole in the right end and the second hole in the left end of the mortise, these two holes will be vertically true because the bit is surrounded on all four sides and cannot flex.
Then return to the first hole and start drilling using overlapping holes as you go.
The second part of this procedure allows the chips to fall away in the area already drilled and so won't interfere with your view.
All of the above is made easier with a MT machine rather then a drill press attachment , especially the added leverage you get with a MT machine verses the Drll press.
I see the power bore bits being offered by Rockler and others that are designed for rapid chip removal and this would seem to be the best bit for hogging out the waste ,though I have not had a opportunity to try them yet.
If you do a lot of MT joints , you will get to like doing them , especially if you buy a machine made to do them.
Some of the projects I have done in the last year or so had forty to fifty MT joints and that is a lot of pulling down on a handle.
Lastly I keep a air hose with blower tip hooked right on the machine and clean out the Mortises as I go.
FredD
