Band saw tires
Band saw tires
Band saw tires
John b. sw chicago burbs
>Hi guys i need your help with a band saw problem. I ordered and received a set of urethane tires. Band tires saw had crowned rubber tires with flat metal wheels. Question. How to put crown on urethane tire or wheel? Thanks John b
Re: Band saw tires
Re: Band saw tires
William H. Falberg
>Sounds like you have to either machine the wheels or machine the tires. I'd go with the wheels so you can live happily forever-after. The radius of the crown should be equal to the radius of the wheel, if your machinist has to ask.
Re: Band saw tires
Re: Band saw tires
DJK
>I have urethane on my 1930's 20" Crescent and a 20" Delta with the grooved aluminum wheels. I filled the groove with bondo and scraped it smooth and level with 4 layers of masking tape adjacent to the groove.
Re: Band saw tires
Caution: urethane tires and flat wheels don't mix
wilbur
>I don't know if anyone else has had this issue, but I put urethane tires on my 1940's era Walker-Turner bandsaw, which also has a flat profile on the wheels. I went with urethane tires based on everything I had read about bandsaw tires at the time. After a couple of years of use, I was making a cut when the bandsaw started shaking. I cut off the power and backed away, and then there was a loud BANG, and the orange urethane tire shot out of the top wheel compartment, having come off the wheel.
Checking the lower wheel, I found that the urethane tire had loosened its grip on the bandsaw wheels, and could easily be slid from side to side. Since there wasn't a side on the wheel to help hold the tire in place, like on the 14" Deltas (and their clones), it was probably a matter of time before the tire came off.
I've since replaced the urethane tires with the old style rubber tires that you have to glue on. The gluing process turned out not to be as hard or as obnoxious as I thought, and the rubber tire was much easier to get on the wheel than the urethane tire was. Plus, I can put a crown on the tire itself.
I think urethane tires may be a great option for the ubiquitous 14" Delta-style bandsaws, which are crowned and have a groove for the tire to sit in. But it may not be the greatest option if you have a bandsaw with wheels that have a flat profile.
Re: Band saw tires
Try Suffolk Machine *LINK*
Lee Schierer - McKean, PA
>The folks at Suffolk machine can guide you through the replacement process and help you get the correct tires for your saw.
Lee
Suffolk Machinery
Re: Band saw tires
Re: Band saw tires. thanks guys
John b
