Hockey & Woodworking
Marc
>Hi Everyone,
Work has been busy, so it has been a long while since I have been in the shop or even looked at woodcentral :( Fortunately, this past weekend I did get to start a new project which let to an accidental discovery. I was jointing two halves of a bubinga slab, and left with glue squeeze out - so where is my scraper? I did mention it has been awhile since I've been in the shop!
Anyway, I recently had the blades on my hockey skates replaced and with no purpose in mind, I kept the old, not-so-sharp, blades. A wha-la moment here - hockey blades make *excellent* scrapers. The steel is thick and holds an edge great! I have mine sharpened with a 1/2" radius and they not only got the glue great, they took excellent bubinga shavings!!! Whats more, I can get a pair sharpened in 5 minutes at the local pro shop for $5! I think I'll be making some holders to grip them more comfortably...
Now, although not as great, if I pull them into the wood at a slight angle, I can take slices - I did this for a little bit just for fun. Perhaps it would work better if they were freshly sharpened. Perhaps I'll grind one to a knife edge and make a shave...
Anyway, I thought I'd pass along the tip - you may be able to find these dirt cheap or free at a local skate servicing pro-shop (they probably just throw them away).
Let me know how it works for you,
Marc
Re: Hockey & Woodworking
Rob Lee
>Hi -
Not so farfetched...about 20 years ago when I toured the Robert Sorby plant in the UK, they were running blades for ice skaters, alongside their chisel production...
Steel in modern hockey skates is hard... the blades can snap when hit with a slapshot..
Cheers -
Rob
Jim Shaver - L6H 6Y0, Canada
>Neat idea Marc,
But my skates are twice as thick as yours as I am a goalie, great for scraping down the crease, but hard to flex for a board I think...might give it a try on some of the oppositions sticks next game, but so little of the sticks are wood anymore...
Take care,
Jim
Shouldn't need to flex them
>If the skate runner has a crown to it, you should be able to just tilt it over and sharpen with the section that contacts the wood. I love this idea.
Ellis, off to the basement to find orphaned skates.... :-)
Re: Shouldn't need to flex them
Marc
>Exactly... Mine were so worn that I don't think I had a flat spot on them - great for scraping, but very slow skating! BTW, my new blades seems to hold an edge much better than my old ones on the ice, so I'll have to wait awhile for them to wear down enough to be relegated to scrapers...
Grind-your-own car or truck leaf springs
Ron Bauman
IEW
>Skates also work great in Texas. Insert a piece of steel, fill with concrete stick in ground and use for a boot scraper. That cow poop just slides off.
Re: The neighbor might not be happy in the morning
Brian in Brighton
