How to remove oil from car carpet?
Bill Tindall, E.TN
>I was hauling a used Delta jig saw home and failed to note that the crank case had a fill hole the enabled oil to run out, as well as in. I dumped about a 1/2 cup of oil on the trunk carpet.
I have the carpet out and the surface oil absorbed in "kitty litter". The carpet has a plastic backing that is a barrier to the oil, s,o the oil did not soak through. On the other hand nothing will penetrate the back side into the carpet either, which would have been my plan had the back been permeable to mineral spirits.
Current situation. Oil is absorbed into about a 8" diameter circle of carpet and it stinks like an old crank case.
Re: How to remove oil from car carpet?
I had to clean it out of a seat once...
John in NM
>Left the window open over night and got a quart in the drivers seat. Go figure. I consulted a professional company - $100 and no guarantee. So I went and bought a pretty nice shop vac and some spray on detergent from a janitorial supplier (what they recommended for soak/rinse). Proceded to apply detergent and vacuum it out, then soaked with water three times or so, vacuuming it out every time, then re-applied detergent. Used up the whole quart of soap and the stain was gone, never returned. Had that shop vac for years and used it a lot, so I guess the vandal did me a favor really.
Jim in Burlington Ont.
Engine cleaner
>Sray engine cleaner on and give it a little brushing then add dish soap onto the spot and give it another good brushing then hose it.
>Sort of on the order of what John suggested. Lots of reasonably concentrated detergent and water. You can always use Dawn dishwashing detergent - that's what they used on the birds and animals involved in oil spills. It is gentle and thorough.
Powdered laundry detergent applied in a paste form also works reasonably well. It will take several applications.
GalenV in Iowa
>I used Simple Green right out of the bottle on a black grease on my cars light gray carpet. Let it set a short time then flushed it with clean water and dry rags to soak it up. Finished with wet/dry shop vac to get rid of as much water as possible. Got rid of the grease.
Founnd this on Simple Green main ingrediant so why it must work so well:
The main use of 2-butoxyethanol is as a solvent in paints and surface coatings, followed by cleaning products and inks. It provides cleaning power and the characteristic odor of Windex and other glass cleaners. Other products which contain 2-butoxyethanol include acrylic resin formulations, asphalt release agents, firefighting foam, leather protectors, oil spill dispersants, bowling pin and lane degreaser, and photographic strip solutions. 2-Butoxyethanol is a primary ingredient of various whiteboard cleaners, liquid soaps, cosmetics, dry cleaning solutions, lacquers, varnishes, herbicides, and latex paints. It also seems to be excellent at killing most insects and arachnids.
It is the main ingredient of many home, commercial, and industrial cleaning solutions; such as Simple Green All-Purpose Cleaner which has been used to clean up oil spills. The primary manufacturers are Eastman Chemical, Dow Chemical and Equistar in the United States
I used Hand Cleaner
Dustmaker Mike
>I had an apartment down in J-ville FL. I had a motor cycle I took apart in the living room. I had a few oil stains on the nice beige carpet. I used the hand cleaner with a little pumice in it then a little shampoo and no more oil stain. It is a lot easier on the carpet and easier to clean off.
I also had to fix a couple of holes in it but that is a different story(-;
Dale Lenz
Re: How about...
Dale Lenz
>taking the carpet to a car wash. There's plenty of warm weather left, should dry carpet out in a few days. ???
Fred Davis
>Simple Green is good at removing oil stains, even on shop and garage floors.
FredD
Hot Spot Cleaner
waroland
Nice to see
Dan Donaldson
>that I am not the only one ;-) When I was a kid, I overhauled a motorcycle in my bedroom. (didn't have a garage or outside place to do it and it was winter. ;-)
Starting fluid.
Basil
>Do this outside in the open. Turn carpet upside down with stain at lowest point and sspot with starting fluid....let oil/fluid drip off carpet then use a foam upholstry cleaner and brush on the spot. Dry and reinstall.
Thanks to all
Bill Tindall, E.TN
>I thought it was hopeless but these ideas are encouraging.
I've used GOOP successfully.....
Tim Greif - West of Chicago
>I got a bunch of oil on my pickup seats once. It was light grey velour. What I did was rub the spots very thoroughly with GOOP hand cleaner gel (without pumice), the kind they also tout as a laundry aid. Let that sit for a while and then do the hot water spray bottle with shop vac routine. You are sort of steam cleaning the spot without steam, just hot water and the GOOP. You will need to do this a number of times, but it will all come out, at least it did for me. And on a light grey velour piece of upholstery, you'd know if anything was left.
However if you have the trunk carpet out of the vehicle, I'd be inclined to soak the area with the GOOP or any other type of general purpose oil solvent like GUNK-GP and power wash it. If you don't have a pressure washer, just soak it good, wrap in a sheet of visqueen and head for the local self-serve car wash. Will probably need a few applications as above.
