Your answers are so vague, it is hard to visualize
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>what you are planning. If you are going to make a cart to transport and or store plywood flat, I would suggest that you re-think that idea.
I have a couple that I use in my shop which have an A frame where the panels lean against both sides of the A. The base comes out about 12" to each side, then I have stake pockets along the sides, where I can insert a couple of pipe, to lean panels against when I want to get the first panel on the inside out first. If you stack flat and want the one of the bottom, you will need to unload the whole cart.
When I build a torsion box otherwise, I normally rip the grid parts from 1/4" ply, then crosscut the dados on the TS sled while the parts are taped together in a tight stack. A loose fit on the width of the dado makes for easier assembly at glue-up, with no loss of strength in the final product.
When gluing up, I like to use thickened epoxy rolled onto both panels and edges of the stacked grid parts. If you are relying only on glue, remember that, if you are gluing onto plywood, the strength of the finished piece depends on the first ply of those panels to be really well glued on. The glue-lines of lots of plywood can be poorly glued on.
I use a vacuum bag to pull it all together while the epoxy cures.
