Re: Motorizing an Outdoor Porch Swing?
Curly Smith
>If you approach the problem as a pendulum and you're asking "how much energy do I need to add to keep the pendulum swinging" then the answer is not much. Note that this is very different from the energy required to start the pendulum swinging.
This simple online calculator will tell you how much energy is in your pendulum system:
Simple pendulum
For example, if we assume a 7' pendelum, 20 degree swing, 600 lbs for the swing and adults, and 1g then we get: max height = 0.42', a period of 3 seconds and 253.3 ft-lb of energy.
Each subsequent swing will be less because of air resistance and friction by a factor along the lines of (h/h1)^0.5 = e, where e must be determined experimentally. But, if we simply assume that e is 0.90 then we find that the system loses 0.1 * 253.3 ft-lb = 25.3 ft-lb per period or 8.4 ft-lb/second = 11 watts (or 0.01 hp).
The real answer will depend on how efficient your pendulum is but it should require very little energy.
