Assembling Plywood Cabinet Sides
howard
>what joint type do you use when assembling plywood cabinet sides? I've been using a rabbit on the ends of two panels that accept the other two and are secured by a 15 ga nail from my Senco. Works fine, but just recently noticed a corner separating. Is the standard to use screws, and if so, what type and kind of screw. Thanks for all your comments.
Re: Assembling Plywood Cabinet Sides
Tony - Memphis
>I used screws in all my shop cabinets. Just regular McFeeley's. Nothing special. Haven't noticed any issues. I glued them too for kicks.
Tony
Dick Coers
>Cabinet sides to what? tops, bottoms, face frames, backs, each other?
Hal Smith
>I use biscuits mostly. Kreg pocket screws would work too.
Terry in Edmonton
>I glue and clamp well and will use brads, finish nails or #8x1 1/4 screws. The fastener I use is determined by whether it is an inside panel or outside on the string of cabinets and whether they will be visible. Putting the rabbit on the sides and putting the fasteners up through the bottom and down through the top will usually solve the visibility issue.
howard
>thanks all - I'm going to switch to screws.
