Veritas - Innovation in Tools
Metal Chimney Question.
Virgil Johnson
>I need to make a decision to install either a Simpson Dura Tech or a Simspon Dura Plus stainless steel metal chimney on a house where it not be possible to have a masonry chimney built.Anyone here have experience with either of these products? Thanks.
Re: Metal Chimney Question.
GalenV in Iowa
>I'm not sure if it is the brand you are listing but the stainless steel is the way to go over the galvanized. Last home I had built I put a Vermont casting wood burning stove in the lower level family room. Black pipe out the side wall then all double stainless up the second story and above the roof. It set on a wall bracket so all I had to do was pull the plug in the bottom tee and run the brush from the roof down and everything fell in a garbage can to clean the chimney. Had one chimney fire in 15 years and put it out quickly and it never damaged the chimney at all. For tall chimney on the coldest night in Iowa to start a fire it took just one crumpled newspaper to start a good draft. The stainless looked just fine so it was not boxed in at all and probably safer anyway. I'm sure the stainless was a lot easier to break top section loose to clean.
My two cents for what it is worth.
John Veerkamp, Western Mo
>Virgil,
I've had Dura Vent (predecessor to Dura Plus) for 32 years. It has held up well and is straight forward to install. The difference between the two types you are considering is the gauge & quality of the SS lining of the pipes. Personally I'd go with the heavier gauge version. For the difference in cost you get greater corrosion resistence and greater burn thru protection in case of flue fire.
My opinion.
John
Bill Turpin in WNC mountains
>The extractives from coal, fuel oil, and/or wood soot contain sulfur which changes to sulphuric acid after exposure to moisture. This will corrode anything except stainless. Install the best. Install with all the recommended braces and connector clamps. Pay attention to clearances to combustibles. An eight inch non-insulated pipe requires an 80 inch total space. 36" + 8" pipe + 36" on the other side. A pine 2 x 4 has an ignition point of � 475�. After years of air drying close to a hot flue this can drop to about 250�
I saw a commercial 12 ga black iron 18" flue with oil soot go from absolutely cold to cherry red in fifteen seconds. To say that it was a fire breathing monster is an understatement! A true, wild flue fire can torch your house faster than you can put it out with a fire extinguisher.
