size of wood screw for cabinet
Bob in Green Bay
>I have a nicely made doors for the front of a case - paneled so not very heavy. It has been a while since putting on doors. What size screw is best to attach to the case?
The case and door are both 3/4" thick.
Do I use coarse thread, fine thread?
Any specific details appreciated
I would like to put them all in for final fitting but am also concerned too much in and out will weaken the screw holes. I always dab in a bit of polyurethane when finishing to "harden" the holes.
Any advice greatly appreciated.
Bob in Green Bay - still a bit of summer here
Re: size of wood screw for cabinet
Ed Mulligan, Cape Cod
>Bob,
Wood screw size depends on the size and type of hinge you are using. Are the hinges euro? butt? applied on faces?
DizD
>You could use a slightly shorter screw for fitting and longer one for final i.e. 3/4" for fitting and 1" for final. This would work best if using traditional tapered shank screws.
What size hinges?
>As Ed said, the size of the screw depends on the hinges you're using. So does the finish of the screw (e.g., brass, stainless). Each hinge is countersunk for exactly one size of screw. If you use a smaller screw, it'll sit below the face of the hinge leaf; larger screws will sit proud and can interfere with the closing of the hinge, not to mention look terrible.
So, it boils down to your choice of hinges, not screws; and hinge selection depends on several things, notably the size and weight of the doors, the thickness of the doors and the style or finish of the rest of the hardware in the piece. The size of the screws will probably be somewhere between #6 and #8, depending on the hinges. You will probably have to use 5/8" long screws, since you don't want them to go all the way through the door or the case, depending on how you lay them out. As to coarse vs fine threads, you're not likely to have a choice. Wood screws tend to have similar pitches. I prefer straight shank screws rather than traditional tapered shank wood screws. If you want brass straight shank screws you may need to deal with a mail order supplier, as hardware stores don't typically carry them.
Hopefully this gives you some perspective.
Ellis Walentine, Host
Tom
>Hi Bob, no idea on the question, but I've never seen anybody from Green Bay on the forum....I'm on the east side.
