ADVERTISE HERE - FREE TRIAL
Old DeWalt Radial Arm Saw
Paul Fahndrick
>I have an old DeWalt Radial Arm Saw I am trying to get some information on. It has a green rough finish, comes with a stand and vacuum and has a 10� blade. On the vertical support is one label that has this info � Model: GW1, Rel: 7, and Serial #: 184383. On top of the motor is another label that says � HP: 1.5, AMP: 14/7, Frame: 196, Volts: 120/240, RPM: 3600, CY: 60, Winding: ME4.5Il.5Kl, and Serial#: 56020816. What if anything can you tell me about it? I would guess it is from the 1950�s � is that about right? It is in fine condition and works great - a little bearing(?) whine perhaps, but other than that - perfect. It appears to be very well made by todays standards. Is it worth keeping in an already crowded modern shop? What value would you attach to it?
Thanks,
Paul
Re: Old DeWalt Radial Arm Saw
>You have really opened a can of worms. Few things create as much uproar as people's opinions of Radial arm saws (RAS). Back in the day (60's maybe) they were the darling of the wood working mags. Sort of one tool shops. You could rip, dado, cross cut, route, plane, make moldings, send mail, weigh things, tenderize steaks and microwave with them. Many people have come to the conclusion they were grossly over hyped and that while they can do many of those things, they don't do most of them well.
I have and old Sears/Craftsman/Emerson one I bought when I was about 16 in the middle 60's. I like it. I got along with it as my only major tool for about five years. I still use it for those things it does well.
I don't have a compound miter saw. Maybe if I did I would let go of the RAS. OTOH the RAS will cut dados and rabbets and half lap joints that the miter saw won't do.
There will be others who will explain to you that it is the worst tool ever built. That's their opinion and they will stick to it.
If you get your saw tuned properly and get an excellent negative rake blade designed for a Ras, you may find you like it. The right blade makes a huge difference.
And, I don't know it empirically, but I suspect you have an excellent version of the saw.
A classic
>Those old DeWalt 10" saws, I suspect yours is from the 60s, were the benchmark for that category. They embodied many of the features that made DeWalt's larger models (12", 16") the darlings of the lumberyard market for many years. Their primary advantages were the transport system of the motor carriage, and the unique tapered indexing mechanism for the miter angle (including 90�).
That saw is a classic and a keeper. If you're trying to sell it, you're up against local lack of appreciation, and shipping is going to add prohibitively to the cost. I'd have to do a little more homework to come up with a value or asking price for you. Maybe you can check what recently sold saws have brought on eBay.
Ellis Walentine, Host
Re: Old DeWalt Radial Arm Saw *LINK*
Phil Joines Krum,Tx
>I used an 18" DeWalt in the early 70's. It was built like a tank and held it'd adjustments as well an any table saw I've used. I think the parts and tooling was purchased from DeWalt by the Original Saw Company. (link below) The may be able to help you. There's also a book on them. I used to have a copy but don't remember the title, it's spiral bound. It went into depth on adjustments and tuneup, well worth having.
Original Saw Co,
Fred Davis
>I believe it's all in what your used to using Barry, I have a Dewalt RAS bought new in 1970, it is well tuned and maintained, hooked to the DC and I would never dream of getting rid of it, use it nearly every time I am working in the shop.
For accurate crosscuts to 16" wide , it's hard equal and I also use a Makita 14" chopsaw every day and never confuse which tool is which for the job at hand.
FredD
GalenV in Iowa
>The Ames Woodworkers Club took a tour of Wolfe Machinery in Johnston, Iowa. They have a large section of their plant filled with old DeWalt saws. I imagine if you want to know more about your saw these are the people who can tell you.
Galen
Wolfe Machinery
Paul Fahndrick
>Great info all! I also went to a site that talked about a book for completely refurbishing one of these and had a DeWalt Co. timeline - it seemed that maybe mine might be from the 50's, but I'll need to do some more research. I have a new(er)table saw and compound sliding miter saw and rarely use the RAS, but when I do I'm very impressed with its stability, fit/finish, minute adjustments and the way it just hums - like a fine piece of machinery should - DeWalt must have been part German! I don't know that I want to get rid of it - but like lots of things around here it is taking up space and is not used as much as it would be if I had more room! If anyone else has any further info I'd appreciate it, but thanks for the links/info you've given. I might dust it off and take a picture and post it for y'all.
GalenV in Iowa
>Paul
When we toured the Wolf plant I was really surprised that they could keep in business for what I thought were out of date machines. They had the machines and tooling to completely return any DeWalt saw to new condition.
I guess if I would just think, the company I worked for used a radial arm saw in our shipping department and made many shipping containers for heavy equipment parts to ship all over the world. Not sure it was DeWalt, but it sure cut a lot of wood in probably 30 years. Shop closed the doors in January 09. Wonder who got the saw?
Galen
>Here's an article you won't have to go very far to read: Badger Pond Article
Here's where you can get a copy of W. Kunkel's book: How To Master The Radial Arm Saw
A Sears RAS vintage 1970 was my first saw. I purchased a book that described how to setup and use the saw. I read the book thoroughly and came to completely understood most of the abilities and liabilities of the saw. I firmly believe that if you take the time to understand the saw you will find it to be a much maligned tool that is vastly underated and under valued. I currently use a DeWalt 7790 as part of my stable of keepers.
Re: A classic
Robert R. Clough - Thorncraft
>Ellis, I had a Rockwell 10" RAS purchased in 1965. It was a beauty. It had a double turret, excellent bearings , a brake and was fun to use. I am sorry now I got rid of it although, I must admit, my Delta 10" Contr is probably more accurate over the long term. Furthermore I do feel safer using it.
American made
>If I'm not mistaken, those old Rockwell/Delta saws were made with pride in Tupelo, Mississippi. When I visited there in the mid-90s, they were still making the bigger models of that saw. Very nice machines. Unique.
Paul Fahndrick
>Hey, Frank - ya beat me to it, I found those links also last night and was going to post them here for others benefit - since they've been so quick to respond and try to help me. Here's two more that I got to by digging deeper into those first two.
http://people.delphiforums.com/snotzalot/sawdust/
http://forums.delphiforums.com/woodbutcher/start
Re: American made
>I don't know where in the USA they were made, but I do know they were USA made. Unique? I guess. I have never seen that double turret on any other saw. I used that a lot. I really learned how to handle a saw with that machine - and how not to also. That was my first big machine.
Re: Radial Arm Saw.... age
mjj
>Based on the serial number on the motor (56020816) I believe the saw was built in Feb 1956. I have the same saw. It was the largest RAS marketed to the handyman, there were larger saws intended for more comercial use.
Justin Szeliga
>I bought one 2 months ago off the side of the road for $20.00. The guy wanted it off his property. I figured if all else failed it'd be worth $20.00 at the scrap yard.
I'm going to have the motor rewound. It should be less than $400.00 with shipping & the saw is something you just don't see anymore. The weight of the parts, the machining, & the reach will all come in very handy. Not as good a a friends 16" saw w/a 24" cut, but 18" is useful.
Peace
JJS
