Dusting and Cleaning furniture
Alan Young
Alan Young
>I was asked by a client if it's OK to use Pledge to dust a bookshelf I made. This lead me to realize how little thought I have given to the proper cleaning and maintenance of the furniture and cabinets I've made for people. I have been using an orange cleaner like this
for most of the stuff in our house.
But I'd like to have a better base of information as to what products are fit for dusting and cleaning purposes. I'm not looking for repair and refinishing products.
I want to be able to recommend a product that removes the dust but doesn't leave a soap,wax or silicon film and will not affect the actual finish as alcohol will to shellac for example.
Alan
Re: Dusting and Cleaning furniture
soap and water
Bill Tindall, E.TN
>I use conversion varnish on most of the furniture stuff I make so that it can be washed to clean it. For dusting, nothing is needed but a rag.
I suspect the cleaning product will differ depending on the finish- shellac, lacquer, varnish, etc. as each has its particular resistance to the chemical components of cleaners.
Anything that leaves a soft film(oil) presumably will attract dust and risk softening any finish.
BIG Ditto . . .
steve mackay
>Know it sounds cliche but the cleaning instructions that come with most things (ie : damp cloth with lite soap & water ) are the safest. I've found that if you go any farther most folks will want to use cleaners with more umph. Speciying "soap & water" can remove the temptation for useing something that may damage a finnish. Remember " KISS" and all is well.
Murphy's and water..
>works on everything except cat p#&&. For that you need something with a little more umph.
Fred Davis
>I would suggest Howard's Feed and Wax unless you didn't want a thin film of wax on the furniture which is a good idea.
Keeping cabinets and furniture clean and looking new works best if your piece defeats dirt and dust sticking to it in the first place.
Howard's product uses Orange oil ,beeswax and Carnauba wax and my wife uses it to not only dust with , but to maintain the finish on her Maple countertop in the Kitchen.
I don't like products like Pledge which are little more then paint thinner with a Lemon smell , not Lemon oil mind you , just the smell and in some instances I have seen cheap finish on paneling degraded by these type of cleaners.
Your wood doesn't need feeding either , that's just more hype.
FredD
