A55 Smoothing Plane
Knock down hardware?
>The playhouse (http://www.peacockplayhouse.org/) wants to have an "Antiques Roadshow" sort of function. Some of the "stations" will be on stage - we can use our ordinary folding tables for those. They want some others to be in the seats.
I have been asked to make the "tables" for the seats. I want to make them so they can be easily assembled and disassembled. The rows are at different levels so the "front" legs will be longer than the back. I was figuring on using 2 x 4s for the apron and legs and 1 x 4s for any stretchers if needed. I was thinking about using carriage bolts to bolt the legs to the apron and to bolt the stretchers to the legs.
Does anyone have any other ideas?
TIA
Re: Knock down hardware?
Stuart Hough
>JL, depending on whatever future use there will be, you could use a two bolt system, where the top bolt woud be a pivot piont, and the lower bolt would be an anchor point. The carriage bolt would be approximately one inch down from the top of the leg, just loose enough to allow the legs to fold up behind the apron, and the lower bolt would be one inch above the bottom of the apron. This could be a regular bolt, and would be tightene snugly to immobilize the leg, and then removed and replace in the hole after the leg was folded up, so as not to lose it. Since the front legs would be longer to accomodate the lower level of the floor in the theater seating, you could cut the leg at a convenient point, then attach the lower portion with a hinge, and use a barrel-bolt on the opposite side to lock it in place when in use. All this would allow the lrgs to be folded up for easy storage, "a la" the ubiquitous card table. Or you could bite the bullet and buy some card table locking leg hinges.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>The easiest thing would be to just buy some card table folding legs.
After that, I would think about bolting the leg from the inside out into the leg through a corner block which crosses between the aprons at a 45�.
>Stuart, I like your idea about having a hinge in the longer legs. I could cut them so that they could be used on level areas. I'll use two bolts, but I'll think about making one a pivoting bolt. I sort of want to have the legs go to the top of the apron and in the corner.
I am thinking about making them so I can remove the legs and store them between the apron stretchers.
Geez, the questions just get tougher
>JL, coming at this cold, and not even really visualizing the situation, I have a couple thoughts for you. One, having worked for a contract furniture company that also made theater seating, I wouldn't make any predictions about the slope of the floor. It could be constant, or it could vary with the row you're in. So, it would be better to come up with an adjustable leg.
I just happened to buy a set of the above at Home Depot for about sixty bucks. They bolt onto a ladder (or in your case, a leg set) and have a foot that can be raised or lowered with a mechanism similar to a Jorgenson clamp. Probably overkill for your purposes, but there it is, a possiblity.
Other than that, consider the old crutch mechanism, consisting of two leg pieces with an adjustable straight piece between them, secured by a carriage bolt and wing nut.
2¢
There isn't a continuous slope.
>The rows are in "steps". Of course this makes it a real PITA to go down the side aisles in the dark as the run of the steps is continually shifting. You have row, step, row, step, etc.
Okay, how about a total rethink?
>How about something akin to an old drafting board mechanism. The legs sit at whatever angle on the floor, and you have either a lockable quadrant mechanism or a notched prop that is used to level the tabletop?
?? I have to think about that.
>Cheap is good. We are a community theater. Basically we make our money by putting on 6-7 plays a year and benefit "galas" and performances. Carriage bolts and 2 x 4 studs are cheap - they only requires time - and I'm usually donating that.
