Vinyl post cap removal
Doug Ridley
>I assume these vinyl post caps are glued on. Can I just tap on them to remove them? Will the glue bond break? Ideas please.
Doug Ridley
Re: Vinyl post cap removal
Ken Oakley-Sunny St. Cloud, Fla.
>Mine juat sit in the post. Tap gently with a mallet and see if it moves
>I would put a block of wood under he edge and give it a rap maybe on all four sides. Then perhaps a sharper rap.
If that did not work I would put a sharp chisel under the edge on each side and give it a light rap and see if that cracked any glue that might be present.
Who knew rapping was a woodworking skill? Oh, wait, this may not be actual wood working.
John Veerkamp, Western Mo
>Doug,
If they used pvc glue, you're out of luck. It is what they use to glue plumbing pipe. It actually disolves the plastic to bond. Good luck.
John
Lee Schierer - McKean, PA
>I just completed a railing on my beck deck and teh caps on my posts came with a small tube of glue, whicnh I used on the four tabs midway on each side. The cap slipped over the post about 1/2"
It appeared to be a PVC glue so it migh be tough to get them off.
Lee
Doug Ridley
>Thanks, that's about what I figured.
