Re: Epoxy glue & WD 20 question
Rich F.
>Short answer I think is that the WD 40 / WD 20 will definitely affect the strength of the joint. But I also think the following:
When the WD 40 'evaporates', the solvent part evaporates and leaves behind the oil (lubricating) residue. What you want to do is remove as much of that residue as possible from the pores of the wood, prior to epoxying, so that the epoxy can get into the pores and bond. So cleanup/soak the WD 40-contaminated wood as much as you can with a volatile solvent that cuts that residue (like mineral spirits/paint thinner/lacquer thinner), then press paper towels or similar against the surface to soak out as much as you can by capillary action. Let it dry for a day or two - depending on humidity and wood density. You may have to repeat. ...Depending on how much WD 40 is soaked in, of course, you should be able to pull out enough to get a decent bond.
Boat restorers have to pull out old fasteners that are lubricated, then re-epoxy that wood. You could go on one of the wooden boat web sites and ask them.
But I think that you should be able to do this, assuming that the boards aren't fully soaked with WD 40, and that they have just been sprayed a bit (--for example, to loosen a fastener.) If you have the proper solvent, and enough solvent, and patience, you can cleanup almost any lubricant contamination.
Good luck. ...Your actual success may vary depending upon your own epoxying habits.
