New Barn
New Barn
New Barn
Ed Wesolek
>Hell-o Fellow Wood Workers,
This post is an acculamtion of working in tight paces for the last thirty years or so. The first was 12 X 16 in my basement. The second is in my current garage at 24 x 24, this is mostly stacked with wood.
I now have a barn that is 60 X 40 with my wood working area 40 x 40 with a 10 x 10 spray booth. The vacuum system is under ground along with a few air lines. This all heated with radiant floor heating using a 50 gallon hot water heater. I am not bragging as I have worked my way to getting this wood working shop. My question to everyone who has given me advise over the years regarding different tools to purchase is what kind of floor covering would you put down while the barn is empty? I have roughly 10K board feet of lumber to place in the one section and I would like to finish the floor before I do this.
Any thoughts would be appreciated. Thanks and yes I will be posting pictures from start to finish. It has been a very enjoyable project in building this work shop. To be conitinue.
Thanks for your continue support as usual.
Ed Wesolek
A wanna be wood worker.
Re: New Barn
Re: New Barn
>Well Good Luck on the Barn, Ed
Ten thousand board feet of lumber may get you started. :<)
George
Re: New Barn
Re: New Barn
mdclor
>Congrats on new new shop! I left my concrete radiant floor uncovered to maximize the efficiency, but I do use rubber mats from Lee Valley beside the tools where I stand the most-work bench, TS, jointer, SCMS, etc. Hopefully more knowledgeable folks will chime in.
HTH,
Merle
Re: New Barn
Re: New Barn
Don Orr
>Sounds like a great workspace-congratulations. Regarding the radiant heat in the floor-is there a significant loss in effectiveness if you cover the floor with something like the snap-together flooring or T&G hardwood ? Soft mats where you spend a lot of time seems like a good idea.
