Vynl fence
Vynl fence
Vynl fence
Doug Ridley
>Neighbor wants me to build a wooden gate for her vynl fence. Question is will screws attach the hinges okay? Or will they pull out?
Re: Vynl fence
Re: Vynl fence
Ken Oakley-Sunny St. Cloud, Fla.
>I have a vinyl fence put up after Hurricane Charley knocked down the old wood fence and the hinges and latches are screwed to the vinyl and they are still tight after 5 years. Probably hold longer then they will in the wood.
Re: Vynl fence
Re: Vynl fence
Kneale Brownson..Awaiting return to CO snows
>Check the thickness of the sides of the vinyl uprights (they usually have a cap that will come off). Some fence products are considerably less structural than others. You might want to through-bolt if the material seems undersized for screws.
Re: Vynl fence
Re: Vynl fence
Brian in Brighton
>Our neighborhood has a few vinyl fences. I think the gate posts also have a 4x4 inside them. Double check.
Brian in Brighton
Re: Vynl fence
Cold weather?
Joe Pack
>Not sure where you are located Doug.
An inherent problem with vinyl, at least from my experience, is that it becomes very fragile and brittle in very cold weather. Stress that would not affect it during hot weather is enough to crack it if the temperature is below freezing.
For what it is worth...
Re: Vynl fence
Re: Vinyl fence
Doug Ridley
>I like the idea of the 4 by 4. I'll check that and if it is not there I can add one. Thanks all.
Re: Vynl fence
Re: Vynl fence
JoeW in Detroit, MI
>My fence has extruded aluminum beams in the posts at the gates. Haven't had a problem.
