Yet Another OOPS
Yet Another OOPS
Yet Another OOPS
charlie belden
>So my oldest pseudo- adopted kid (she's now 28 so I should probably stop calling her a "kid") and I are making a bat house for a family of bats that have taken up residents on the side of her cabin. The idea is not to chase them off, but to provide them with a nicer place and encourage them to use it.
She picked out some suitable old weathered redwood fence boards from my stash behind the shop. A front, 2x2 spacers, a back longer than the front to provide a landing place and a board for a slanting overhang roof - a little glue - done.
Now weathered redwood fenceboards, especially if they're 25 or 30 years old, develop cracks - which we fixed with some CA glue prior to cutting our parts.
With all the parts cut, we put them on Das Bench - the one that took a year of elapsed time to make - and after dry fitting everything to make sure we were good to go for glue up - we began the glue up, using "water resistant" tite-bond glue.
Patience isn't a quality either of us posses so I'd turned on the compressor and got out the pin nailer.
Back board on the bench, 2x2 spacers on top, a little glue, assemble - and toe nail in some pin nails to hold things together so we could flip it over and do the front. And since WE (always share the blame when possible) had a pneumatic pin nailer, WE shot LOTs of pin nails - just to make sure things stayed together.
I think you can see what's coming. Pin nail through the bottom edge of the 2x2 into the 3/4" fence board below. Do the math - 1 1/4" long pin nail, 3/4" board, toe nailing into bottom edge of 2x2 spacers.
So when WE went to turn things over - surprise!
"The CA glue hadn't set - and I've glued this $%#@!!-ing thing to my bench! CRANUS! CRANUS! CRANUS!"
A cut off against the now affixed board, a bit of tapping with a mallet - NOTHING. A few more forceful taps - NOTHING.
The benchtop is waxed - this should come loose!
And it would have - if the problem was due to glue. It wasn't.
The 2 pound Dead Blow did the job - and revealed the source of the Sticking Problem - 16 pin nails driven THROUGH the parts - INTO my benchtop - that I'd spent hours and hours making "pristine".
Fortunately - the pin nails were shot in at a shallow angle - and fortunately WE hadn't used 1/4" crown staples - so the damage was limited to some small scratches and a "few" pin sized shallow holes.
To add insult to injury - or more accurately - to make US feel even dumber, the glue had had no time to set and the toe nailed pin nails pulled out and we had to try again.
Knowing that bad things often come in threes, we were exceedingly careful with the rest of the assembly/glue up/pin nailing.
A little caulking and the bat house was good to go. The bat family has since moved into their new home and I've got a bench top to refinish - sometime in the future - probably the distant future. Reminders of Stupid Human Tricks are often nice to have around - for a while.
Got an OOPS of your own to share - and maybe serve as a School of Hard Knocks lesson others might benefit from?
Re: Yet Another OOPS
And Yet Another OOPS
Mike Caldwell
>Yes indeed. Couple nights ago, I set out to dovetail the corners of a bunch of drawers I was making. After a couple drawers, I thought I ought to check some measurements. dry fitted a drawer, and boy did it look odd. I had set my boards in the jig the wrong way and had reversed the tails and the pins. Luckily, only two drawers, and I had extra stock.
There is not enough room on the site for me to describe my goofs.
Mike ;-)
Jesse Cloud
>Can't imagine how this happens, but grain that flows nicely from piece to piece during dry fit, starts flowing in different directions when I glue it together. Did you know that titebond can change the grain direction in wood?? Couldn't have been anything I did... ;^)
Don't you Love Intellectual Flatulance!
Dave Anderson (PacNW)
Re: Don't you Love Intellectual Flatulance!
charlie belden
>Took me more than a few moments to translate
- Intellectual Flatulance = the vernacular Brain Fart, which I've also heard described as a more politically correct Think-O, the mental equivalent of a Typo.
One of the great things about WC is that the posts require some mental exercise - very important as one ages.
AZ, Colorado Springs
>I'm making a tool chest using the plans provided in a recent issue of Popular Woodworking. Lots of dovetails and interlocking grooves, turning out pretty good, I think.
The author (Roy Johnson?) used (and uses) all hand tools. Well, I don't have the necessary tools, or the skills (yet, but I'm working on that) to do it by hand, so I used a router and dovetail jig.
On the skirt boards the dovetails are set to one side, to leave clearance for the groove that interlocks with the main case sides. I had a dickens of a time getting the pins and tails to line up properly, so I decided to route the tails and hand cut the pins.
So I routed tails at both ends of all four boards -- and had to start over with new pin boards.
Oops. (Fortunately, there were other uses stock I had spoiled.)
Roy C. Gryder
>Not a woodworking oops but one of my favorites
I filled the windshield washer tank on the car with the blue fluid in the jug in the garage. Turns out that mixed Miracle Gro is blue too. The wipers did not grow. R.
DaleLenz
>Since fert. is a salt, might make a good windshield-antifreeze mixture. Might be more than a buck a gallon, thought(?).
