Have a question? Ask Woody!
Will glue stick to a stained surface?
Bruce, a MN Galoot
>I'm building a book case for my son, 36" wide and 6' tall, five shelves, face frame, with the bottom three shelves fixed and the top two floating. I would like to at least stain the sucker before I put it together, but am concerned about glue sticking to any stain that happens to get into the dadoes or shoulders. It would be really nice if I could get some varnish on it before assembly, but that's asking a bit much. I don't have spray equipment.
Thanks.
Re: Will glue stick to a stained surface?
steve mackay
>Not in my jungle. Not to glue or the marks from those cute plastic clamp pads either. I'm sure its only in my shop though. :)
Fred Davis
>If you use a water borne Aniline dye for the staining agent you will not have any adhesion problems with a water base glue , like Titebond or Elmer.
A stain agent suspended in a oil base , like Minwax for instance might be a problem.
FredD
Dave Bair, Eaton Rapids, MI
>Use a water-based dye or use painter's tape to mask off the to-be-glued areas.
Jesse Cloud
>Sadly, the answer is "If you want it to stick, it won't - if you don't want it to stick it surely will." I would take the advice on painter's tape, though be careful not to cover something that will show after assembly with tape.
Howard Acheson
>If you are planning to use an oil based stain, the stain will affect the adhesion of the glue. Oil based stains contain a small amount of varnish which will fill and seal the pores. This prevents the proper absorption of the glue. However, if you use a dye stain, the glue joint strength will not be affected.
Thanks, guys and
Bruce, a MN Galoot
>darn!
I'm using an oil-based stain to match the other stuff I've made for him. Guess I'll just have to be careful.
Thanks again.
Bruce
Re: Thanks, guys and
Jerry Samsen
>I just finished assembling base cabinet and bookcase. I stained using 1lb shellac + oil based gel stain but masked off the edges that were going into dados. Keeping out of the dados was easy.
