Epoxy under a vacuum
Dave LaPine
>I'm looking to do some intricate work on a small piece of burl and am looking to penetrate the entire piece with some type of an epoxy under a vacuum. I think the epoxy should probably have a fairly thin consistancy and be able to penetrate completely before it sets up. Anyone played around with anything like this?
Re: Epoxy under a vacuum
Consider using cyanoacrylate adhesive
Bill Tindall, E.TN
>The thin stuff will penetrate wood well because it has very low viscosity. Actually, hide glue penetrates well also.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I have done that on some really badly buckled bees-wing, and fiddle-back veneers that needed to be flattened. It did a nice job of holding a set, and kept the little pieces from falling out when I cut the edges straight.
Of course I always use epoxy for veneering, so there was not a problem of different looking wetness from two types of glue.
Is that what you are thinking about using it for?
Re: Epoxy under a vacuum *LINK*
Dick Coers
>Pen turners and knife makers have been doing self stabilized wood, but I prefer sending mine out. They sell wood, or will stabilize yours. It's more light a plexiglas material than epoxy, but it makes the wood cut, feel, and finish about like plastic.
wood stabilizing
>One of the artist's that I photograph for had an article in (I think) American Woodworker sometime last year on what he calls Outlay. It is basically a built up veneer product that is impregnated with epoxy under a vacuum. It makes an incredibly tough product that will take very fine detail.
The article had a full page shot of a giant Yellow sea horse that he made out of the material. I can probably find that issue given a day or so. I believe he talked about how to do it but would have to go back and read the article.
for the big stuff you could use one of these. *LINK*
Victor Parisian
>My company worked around one of these but much bigger down at Morgan's Point, Tx a few years back. You could park a small truck in it.
Should do the trick.
Victor
VPI Tank
Take 2. They're small.
Dave LaPine
>Keith- I'm actually going to play around with it on my metal lathe using an air pencil grinder in the tool holder for some of the cutting. I have a project in mind for it but am just looking to do some experimenting with it for now.
