I need to do preventative
Gary Smyth
>maintenance on a piece of 20 gage (gauge) metal that over years has vibrated a hole larger than it ought to be. My first reaction was to add a washer or similar, but that won't work. Next I thought to have a patch piece welded on to the area and drill a hole through the patch and move on my merry way. But the metal is relatively thin and the tool is very difficult to move to a remote location (I do not own a welder and couldn't do it on my own if I did). I was told that auto people deal with thin metal all the time and they patch their problem using industrial, expensive, VHB (very high bonding) tape to accomplish the same result. Anyone ever try to permanently bond a repair plate, steel to steel, using VHB tape? All I want to do is prevent a breakthrough of the original metal by bonding a extra thickness of metal over the original. Thoughts?
Re: I need to do preventative
Pete in Holland, MI
>Not sure exactly what you are trying to repair, but if attaching another piece of metal, like a patch, is acceptable, then do so. Smearing the mating surfaces (cleaned well) with RTV silicone will do a good job of bonding them together, along with some pop rivets or nuts & bolts.
BrianA
>JB Weld? works really well.
Brian
Perhaps some additional info.
Gary Smyth
>The metal piece has a spring attached through a hole in it. That spring is attached to a similar metal piece over a distance of 18". When the motor runs the spring pulls the two metal pieces together in tension so that they do not flop away. Over the years the spring has vibrated enough to wear a "keyhole" in the hole. the hole is near the panel edge. Vibration is now wearing through the hole and heading toward the edge. By adding metal to both sides of the original piece it should hold for another thirty years. Failed methods are JB Weld, Epoxy, Gorilla Glue, Instant glue, Construction adhesive. I'm still looking for something that will hold under heat and vibration.
Re: Perhaps some additional info.
GalenV in Iowa
>Still hard to understand with out a picture. If the hole is close to the edge of the metal as you indicate then fold a patch over and sandwich the old piece. Then just sheet metal screw or rivet the top two corners. Sounds like the spring may have a hook that goes through the hole and over the edge? Can you put a small eye bolt through the patch with washers and nuts both side and hook spring to it? You would not need anything more than the eye bolt to hole the patch.
Old saying a pictures are worth an thousand word, but I have no picture of the suggestion!
Galen
Dan Donaldson
>Could you sweat solder something there? That would probably hold.
>Since the hole is near the edge (I think?) how about attaching the spring to the frame. Perhaps straps that would wrap around the frame.
Gary Smyth
>Pictures inserted on WoodCentral are hard for me. I have the camera, and can get the shot to Picasa of attach it to email but cannot move the picture from there to WoodCentral. I read the directions to do it I just can not make it work. That being said, I looked earlier for small eyebolt --nothing small enough. I also tried the folded metal,22 Ga, and while that will work it looked bad. I wasn't anxious to add more holes for pop rivets either. I had to use the tool so I went the route of Very High Bonding (VHB)tape, courtesy of a local signmaker, sandwiched on either side with metal fitted pieces on both sides. Although thicker in profile with a little bit of paint it disappears. I'll take my chances on how long it will last. Thanks for the ideas.
Gary Smyth
>Actuall there is room to do as you suggest it will work just not elegant enough. Still, if my first "solution" does not pan out, I think your is next until it works or I canfigure out a better fix. Thanks for the thought.
Hummm, I wonder? Down the line perhaps
Gary Smyth
