Quick Finishing Question...
Rob Hix in King George, VA
>Hey all,
Really quick finishing question here. I have got a really good finish on this desk top that I am working on. It is satin water based polyurethane. Is it absolutely necessary to sand between coats? I always do because I have heard it is necessary, but is it really?
Thanks for the info,
Rob Hix
Re: Quick Finishing Question...
DaleLenz
>Never used water based poly. I usually put 3-5 coats of something on; shellac, lacquer, varnish and sand.
Depends
>If the surface is pretty smooth, I wouldn't bother. You should always check for roughness and nibs, though, and knock those off before recoating.
>I always have a little fuzz, so I usually hit it with some 220 grit.
Howard Acheson
>There are two reasons for sanding between coats. First, is to smooth and flatten the surface. This is most important after the first coat. The first coat will raise the grain and sanding with 320 paper on a sanding block will flatten and smooth surface. The second reason for sanding is to scuff the surface to provide good adhesion between the existing finish and the new coat. Whether this is necessary is dependent on what the finish manufacturer says in the instructions and how long a time has elapsed between coats. With top quality waterborne finishes, if you re-coat within 5-6 hours, you do not have to scuff sand for adhesion. Scuff sanding should be done with 320 paper if necessary.
>Thanks for the info. I went ahead and scuffed it up. However, I am just going to live with the dust in the finish after the second coat. I usually use paste wax and 0000 steel wool. This makes the finish far too glossy for my tastes ( I am using satin polyurethane). Over time the nibs will go away. They weren't too bad after the first coat, so maybe they will be better this time.
I hope to get this done tonight. However, it is not looking really good right now.
Thanks again,
Rob
