OT - Dehumifier water - Potable?
Brian in Sandusky, OH
>I run a dehumidifier in my shop.
It seems a shame to just dump it out. In the Ohio summers, it seems like I'm dumping a gallon a day out the backdoor.
I'm thinking about setting the dehumidifier up high, and route the water to a larger container via gravity.
Then I could use it in the shop, water the garden, etc.
But if I were thirsty, is there any reason to NOT drink this water? Fill the kiddy pool with it?
Just curious. Water is expensive in my area, and every gallon would help.
Re: OT - Dehumifier water - Potable?
Nat Robison
>There was a thread on this earlier this summer and it was voted a big no.....mainly because the coil isn't clean and your receptacle isn't sanitarily clean. Water things? Yes. Drink? No.
Grant in Iowa
>Couple thoughts:
1. A dehumidifier is essentially an air conditioner with the condensor and evaporator in the same room. Why not replace it with a small air conditioner (compare the amperage ratings with your dehumidifier) for the same money spent on your electric bill. Since I have done this, I enjoy both a dry and cool shop for the same electric cost as a dry shop.
2. Water from your dehumidifier is essentially distilled water less the sterilization effect. I would not drink it as it likely has a lot of mold and mildew spores in it as a minimum. On a constantly running dehumidifier, the evaporator likely remains wet for days on end, and is likely an incubator for mold spores. Not sure how good distilled water would be for plants, since it lacks minerals, though the grass under my small window A/C is very green and happy. It would be excellent for cleaning cars, windows, and clothes since it doesn't have significant minerals in it. No water spots.
FWIW,
Grant in Iowa
al heath
>water from a dehumidifier or an air conditioner is NOT distilled. It is condensate. Distilled water is from Distillation, a process in which water is (a) heated to boiling and distilled through cooling coils (plates) or a condenser or (b) brought to reflux by applying vacuum and heat and then condensed through cooling coils or a plate. Condensate is formed through neither of these processes and should NOT be considered distilled water and could potentially be very unhealthy to drink.
>I use my dehumidifier water to water my tomatoes. It works quite nicely. I would NOT drink it.
In the summer I pull out about 3 gallons a day. Which is enough to handle most of the tomatoes.
