Varnish Questions
Brian in Brighton
>I recently completed the walnut mantle that I wrote about a couple months ago with the bleaching question. I have another one.
I brushed a coat of interior Benjamin Moore Varnish onto it and was getting ready for the second coat and stopped. I have some debris in the varnish that I can remove easy enough. But the varnish was pterry thick brushing and cured quickly enough that you can clearly see the dividing areas from one brushing zone to the next. Varnishing the underside was a real chore and I got a few drops that backed up the brush.
My question 1 is this. Can I sand with 400 grit and then thin the rest of the varnish 4 parts varnish to 1 part mineral spirits and then wipe on the next coat?
Question 2: I want a matte finish when I'm done so I plan on using 0000 steel wool on it, like I did on the columns next to the mantle last year. How long should I wait before I do this?
Thanks,
Brian in Brighton
