Cutting Miters?
Cutting Miters?
Cutting Miters?
Tony - Memphis
>I've cut many miters. Probably not more than I few that I've been happy with though. I'm finishing up work on a tray topped tea table right now. I was working on the cove molding for the top the other day and buggered the whole thing up to make along story short. So, now I have to start over and make some new cove molding. Which is a pain because the outside curve is all done by hand and curly maple tears out a lot. Anyway, because the outside profile is a curve, it makes cutting the miters very difficult. So I started thinking about different ways to make miters and thought it would be interesting to hear how other folks do it.
I've used my miter saw, miter gage on the table saw, a shop built sled, etc. I use a Lion trimmer copy to fit the joints most of the time (it failed me this time - kept wanting to roll the work piece over).
Here is the table. The picture dosen't show the issues. The large cove on top is what I am having problems with. Hard to tell here, but the molding is a cove with the outside being a curve. I cut the cove on a wide piece, then rip it off with the saw at 30� and then finish the curve by hand. The smaller molding around the table was pretty buggered up too, but I was able to save it. No miters on the next project!
Tony
Re: Cutting Miters?
Re: WAG
DaleLenz
>How about cutting and fitting the miters prior to making the profile, possible(?).
Re: Cutting Miters?
Re: WAG
Tony - Memphis
>You know, I had a similar thought. My fear was that while shaping the profile, I would get tear out at the ends and I might just rip the whole thing apart trying to work the profiles. So my next thought was maybe just leave a small flat on the edge to register off of and then finish that up after I glue it up. I was also considering pinning the corners with some 1/8" pins to give it strength.
Thanks,
Tony
Re: Cutting Miters?
Stops on your miter saw?
>One way is to use stops on your miter box so that when the molding is leaning against the fence in back, the stop in front holds it in the exact registration you want.
Another way is to leave the molding blanks long and only shape as much as you need in the middle. The square ends can be used to register in whatever miterbox setup you choose.
Re: Cutting Miters?
Re: Stops on your miter saw?
Tony - Memphis
>Good ideas. Thanks. I had seen that (front stop) on NYW and thought about making a "channel" to attach to the miter gage. I guess there are a lot of ways to do this. I think I may try that on the miter saw and see how I like it. Not too hard to setup and nothing to lose. I've read that miter saws aren't known for accuracy, but this Hitachi seems to be pretty good. It probably needs a good sharpening or a new blade. I read that some folks use those high tooth count blades. I'm not sure what came on the saw, but it still cuts pretty well. Getting it set to 45� is difficult. The stops aren't very reliable. But that's just patience - cut and check, cut and check, ...
Tony
Re: Cutting Miters?
shooting board and nibbliing
Bill Tindall, E.TN
>Philosophically, I nibble miters into submission. On an outside frame like around this handsome table I would cut the 4 pieces of molding purposefully long with approximate miters on each end. (approximate refers to the angle which may not be 45.00 degrees at each corner, at least on my stuff). I would then hand hold the 2 molding pieces to one corner and see if the miter closed. If not, I would nibble at the two mating pieces with saw or shooting board until it was perfect. Ok, now joint #1 is perfect with respect to angle. Then temporarily tack the short table end molding piece down such that it makes a perfect miter at joint #1. Then I would move to the second corner and do the same, only worrying about the fit of the miter, NOT the length of the pieces. At this point the saw or what ever, is set to make a perfect angle of miter on joint #2. Now use this setting of saw, or what ever, to trim to length the piece of molding that goes from joint #1 to joint #2, using a hand held piece of molding #3 to judge the length fit. When the length is perfect, nail on Piece #2. Continue around the table in the same manner.
If I can, I clamp hold the molding whilst nailing so that nothing moves during nailing. This operation is hard because the angles need to be within +/- 1/10 of a degree and the lengths to less than +/-1/64 to look good.
Re: Cutting Miters?
Re: Cutting Miters?------WebKitFormBoundaryp2zyOL4
Warren White------WebKitFormBoundaryp2zyOL4fdWzE2x
>Not possible....desk is not capable of being saved.....I will take it off your hands as a favor......
Hope you can see my tongue firmly planted in my cheek. That is very, very beautiful. Please post pictures when you are done. WOW!!!
------WebKitFormBoundaryp2zyOL4fdWzE2x+Q
Re: Cutting Miters?
Bill White
>Have you ever "indicated" your miter saw? By that has it been accurately adjusted at 90* and 45* stops? If this has not been done, and if you're not using a good 80 tooth blade......Well 'nough said.
Bill
Re: Cutting Miters?
Re: Cutting Miters?
charlie belden
>Interesting and not at all uncommon issue to deal with, complicated by the fact that the molding isn't off the shelf stock you can go buy more off, and the wood expansion/contraction issue acrossed the end of the top.
Have you considered putting a rabbet/rebate on the underside of of the inside of the molding? This has two advantages
1. It gives you a nice notch to register and "stop" the front of the molding if used with a jig when cutting the miters. (see attached illustration)
2. It also gives you some adjustment/wiggle room to get the mitered corners nice and tight - with some tweeking available between the ends - IF the angle on the corners of the top aren't actually 90 degrees, or the mitered corners aren't actually 45 degrees each.
Re: Cutting Miters?
Tony - Memphis
>I've never trusted the stops (on any of my equipment). So I don't rely on them. I use them as a rough guide as to "about" where to stop, then I cut and test until I feel like I am real close or I lose patience!
I just got back to this project over the weekend (outon vacation). I set the saw up with a nice new flat MDF fence and started getting the angles set. I got the one side set and made the cut on each piece. Then, I got the other angle set and used a stop block to set the lengths.
I left a flat portion on the backside of the molding to register by. That made a big difference. I could even tell when I was testign it on my miter trimmer. So far, the cuts look pretty good. I haven't tried to assemble the whole frame yet. Ought to be fairly close and I can probably use the miter trimmer to finish it out. I glued a test corner with liquid hide glue and was surprised by how strong the joint was. I'm still planning on adding a dowel to each corner for safety. And, when I glue it down, that ought to hold it all together - I hope!
The blade I am usng is the stock Hitachi. Not sure what it is tooth count wide, but it still makes a pretty nice cut after all these years. I'll probably yank it off and send it in for sharpening soon though. It's due.
Tony
