Right, Left, Mirror images
Jerry Gibbs
>When the plans call for a right and left version of the same drawing, or a mirror image, I am in trouble. I am not dyslexic, although I reverse numbers easily. I waste wood and spend time correcting errors. Is the any cure or exercise to ease the problem? Jerry Gibbs
Re: Right, Left, Mirror images
Give us a for instance
steve mackay
>I invest in plastic sheet. Not heavy plexi-glass. Just thin paper-thin sheet. Trace over my drawing then do the flip-flop. Then I KNOW, deep in my heart, I'm going to match. Don't even try to flip-flop numbers any more. I'm not good with numbers or math and I'm smart enough to know it. I keep files of my past templates just in case.
GalenV in Iowa
>Some people just have problems visualizing the opposite hand of anything if there is no picture to show it.
To help our fab shop we ran the original vellum plan through the copy machine face down(upside down)to make the opposite hand image. The numbers are backward but that they can read from the original.
You can make a print on translucent paper and just look at the image from the back side or through the paper.
Photo and other computer software allow you to flip an image which will give you the opposite hand.
Many copy centers can flip the image on a print to at least give you an image to look at if you have no options at home.
If you make a light table you can put your plan sheet on it upside down and look through the paper.
As the term implies you can also hold the print up to a mirror and see the opposite piece but hard to do while your working in the shop.
Great thing about Autocad is being able to quickly create the opposite hand of pieces so a lot of our problems were solved by clearly showing both.
Fred Davis
>I can tell you how Carpenters do layout for housing ,when the plan is drawn for a right hand layout and some of the houses with identical layouts are using a left hand layout .
This is common in cookie cutter type subdivisions where the Facade may change, but the floor plan is the same only reversed.
They will hold the floor plan up to the sun and read it from the back side of the plan, the numbers will be reversed , but once you get used to doing this , you can reverse nearly anything in your head.
A good Architect will furnish identical layouts in both right and left hand, but you have to ask.
FredD
Tony - Memphis
>Well, I usually make two lefts! For table legs, I place the leg blanks in a bundle in the orientation I want. I then make markings on the tops of the blanks showing the outside faces, inside corners, and left or right (facing the table). I mark the mortises and then put the bundle back together to make sure it makes sense.
Tony
Re: Look thru the plans
Brian in Brighton
>Take the plans and look at them towards a bright light. The image you see is the mirror image of the parts.
Mirror images
Yonak
>I wonder why, when I look in a mirror, my image is reversed left to right, but not top to bottom ?
Re: Mirror images
charlie belden
It does but we don't realize that we're actually upside down because we're on the OUTSIDE surface of a spinning sphere. Now if we were on the INSIDE . . . ; )
