cedar oil on wardrobe closet
jennie
>The carpenter made me a nice wardrobe for a little room. After he had it all fastened to the wall and I walked passed it for a week and I put in my first garment I realized I should have had it cedar lined. It is nicely varnished but I think it is only one light coat. Can I rough it up a bit and rub in cedar oil? What kind? Where would I get it? How would I do it?
Re: cedar oil on wardrobe closet
Interesting question
>The short answer is, most likely not. You won't get to the bare wood (what species are we talking about anyway?) by scuff sanding the varnish; you'd have to strip or sand all the way through. I've had "cedar oil" products in the past, and they are definitely oily, so I'd suggest putting them on raw wood, where the oil will be absorbed by the wood tissue and you'll have the benefit of the vapors from the oil, which is what you want. If you put your clothes in an armoire with oily walls, you're asking for trouble.
One workaround would be to re-line the inside of the closet with thin aromatic cedar strip planking which is sold everywhere for this purpose. Leave it natural if you want the smell of the aromatic cedar.
Ellis Walentine, Host
Two or three thoughts.
>I would be suspect of the cedar oil and the existing finish, even the residue of the existing finish. There might be a chemical reaction and you could end up with a gummy mess.
Why not make a sash of wood ships and cedar oil or buy one?
And, I hate to rain on a parade, but research by the entomologists as VA Tech found that cedar had no effect on insects. The odor does not kill or repel them. And the aromatics in it can ruin elastic. If you shut up something with an elastic waist band in a cedar chest for a few months, the elastic may be relaxed when you take it out. (Does modern elastic still have rubber?)
The reason cedar chests worked was that the advice was to clean the garments before storing them in the sealed box. Cleaning them eliminated the insects, eggs and larvae. If the box were sealed, new ones could not get in. A whole industry based on a myth.
>Good Morning Jennie,
I agree with advice given by Ellis. Either buy or mill aromatic cedar slats and install them on top of the existing cabinet walls. You'll have a quick, neat job without contending with the mess of stripping/sanding the existing finish in a very cramped space, and the certitude you'll have authentic cedar aroma. As for Barry's bug mythology, he is correct. However, I like fragrant myths better then vagrant moths. :<)
George
Fred Davis
>In Craft shops , hardwares, Bed and Bath shops etc. , you can find small net bags of Cedar chips for the exact use your looking for.
I have seen them for about a 1.50 to three dollars and realized how much money I have thrown away ,after planing Aromatic Red Cedar;-((
FredD
Ouch
>I think you've outdone yourself this time, punmeister. :) Vagrant moths indeed!
