Shellac finish problem
Ed F.------WebKitFormBoundaryRku3iypSUZ+t93xk-----
>I've made a large picture frame from reclaimed knotty pine. I'm finishing it with amber shellac (canned) to recreate the vintage golden-orange of the original tongue and grove paneling boards I started with. This is my first time using shellac since high-school shop class. The shellac dries so quickly I'm having trouble getting it brushed out even before it starts getting sticky. All advice welcome.
Re: Shellac finish problem
Loose The Brush
>and make a pad.
Take a piece of lint-free fine cloth (old cotton T-shirts) about 6" square. Then make a ball of anything absorbent and wrap it with the cloth square so you have what looks like a little bag. This you can "charge" or dip into the shellac and then apply your finish in long strokes with gentle pressure but don't go over a previous stroke. Apply a coat, and let dry for an hour, then repeat. Your finish will build and the color deepen with each application. Just remember not to "work" the finish film like you did with a brush. Most imperfections will get corrected with the next application. When you've got a good layer applied, you can level the surface by wet sanding with 400-600 grit and then polish with a bit of compound or wax.
Have fun. Shellac is one of the easiest and most forgiving of finishes we have to use. If you mess up, just rinse it off with alcohol and start over.
mm
Larry Clinton at Frankfort (Central)., Indiana
>Mark is correct, one other item ~ I find most pre-mixed shellac to be to heavy a cut for my liking. I normally mix my own from flake. You can pick up some denatured alcohol and reduce the cut to anything you like. I find it is much easier to reduce the cut by half and add more coats.
Bill Tindall, E.TN
>I never had any success brushing shellac. But while arranging our club program for tonight we discussed the topic with our presenter, Buddy Floyd, master cabinet maker. He successfully brushes shellac. He uses a 1 pound cut and a "badger hair" brush. In essence, the brush has very fine bristles and it holds a bunch of shellac.
I have had good luck padding a thinned coat onto things and a foam "brush" works if you work quickly. Eventually the gray foam brush will disintegrate. You can make your own from white upholstery foam and they last.
I spray it. Works great.
Dave Bair, Eaton Rapids, MI
>I've had success using a 4" white foam roller to apply the shellac followed by a swipe with a synthetic-bristle brush to even out the surface and pop any bubbles. Don't know if your project is large enough to justify all the materials, though.
Re: Shellac finish problem *LINK*
Dan Donaldson
>You can also try Behkol to thin it instead of straight alcohol. It is a mix of different alcohols and dries slower. I usually use it for mixing my shellac and it seems to work well.
behkol
>Thank you all for the quick and informative responses. I'll try Mark's pad suggestion and post a picture when I'm done. I'm framing a 3ft square piece of carpet my dad made in the fifties when he ran a jaquard loom in a carpet factory making custom commercial carpets. This one was for a Las Vegas casino.
Ed.
Fred Davis
>Don't brush it out , apply a wet coat , one stroke and do the places you missed the next coat.
Brushing is a skill acquired with lots of practice, spraying with a pressure can of Shellac isn't.
Badger hair brush don''t hurt either.
Sounds like a small project, I suggest spraying.
One note about padding, it is a technique borrowed from French Polishing and works well.
But the notion implied that you can't brush large areas of Shellac is not accurate, I have recently for instance recoated a two foot wide strip around outside edges of a Parlor and Bedroom in a rental I own with a six inch Baker Chinese bristle brush. Shellac laid down like glass.
The remainder of the Shellacked rooms is carpet, for the time being, over a Oak floor laid in 1926 when Shellac was the finish of choice for Hardwood floors.
Zinsser's Bullseye spray shellac is a good one.
FredD
Right on
Kneale Brownson..Awaiting return to CO snows
>I've brushed shellac repeatedly to seal in animal urine odors in rentals before replacing the carpeting over hardwood floors. I also use it as a finish occasionally. The Badger Hair brush makes a significant difference. Padding the stuff on means a lot of coats. A good brush lets you build a finish with fewer coats. The secret is to move quickly and don't be fussy.
Spray, spray, spray
Rob Sandow
>I have brushed shellac successfully. But I have also brushed it unsuccessfully a number of times. Contrary to popular belief, it has worked best for me in a 3 lb cut and not dewaxed with a brush. Too much thinning and the alcohol evaporates too fast.
However, the easiest way to apply it is with a spray gun. About a 1 1/2 lb cut works well for me. You won't get a "French polish" shine, but it does go on evenly and without orange peel. You don't need expensive equipment. The $30 spray can from Home Depot and a halfway decent oil-less compressor is all it takes. You only need the ability to run the compressor continuously at about 20 PSI. Use a good organic vapor mask.
Rob
Alexander Grigoriev
>I, too, use a white roller to apply shellac. I don't let it form a film, though. Just keep saturating the surface for a while, then wipe it dry. Let the spirit evaporate. Then I apply my favorite Zar Max - oil-modified waterborne poly. It darkens the color a little bit more (quite like oil poly); floats excellently. And doesn't smell (unlike oil).
