OT: Changing Lawn Tractor Tire
Tom MacGregor
>Does anyone have any nifty little tricks for removing a 15 x 6.00 lawn tractor tire from the rim and installing a new one without damaging the bead? Those @%#*! little ones are worse than car tires.
Re: OT: Changing Lawn Tractor Tire
Basil
>The little boogers are #%$*& to get off ain't they.
I just take mine off the mower and lay it in front of the tire on my pickup....then drive over it. You have to be careful to place it so that you drive over the tire part and not up on the steel wheel and damage your truck tire. Flip it over and do the backside....usually works for me.
Once you have broken the bead loose from the wheel they're pretty easy to get off the wheel...and I usually put a innertube in mine while I'm messing with it.
I always forget something.
Basil
>Smear some liquid soap on the bead when you go to mount the tire. It'll make it easier to mount and will insure a better seal with the rim if you go back tubeless.
Dave Bair, Eaton Rapids, MI
>I drive 4.5 miles to the one remaining gas station that fixes flats in my area. They snicker until they actually try to get their machine to work on the small tire. They eventually figure it out and only charged me $5 last time. To me, it's a bargain.
Re: I always forget something.
jared
>This is the way I do it, drive over it with another vehicle. It takes a little practice but unless the tire is rusted on, it will usually pop right off. You can also pound them off the bead with a spud bar and a heavy hammer but that is more work. Jared
Re: OT: Changing Lawn Tractor Tire *LINK*
Jim Dillon
>Coincidently, I just had to do this on my 40 year old Jacabson (flat front tire). Liked doing it so much, I did it three times 8-)8-). It is TOUGH to do and the smaller the tire, the tougher it is. My tire was 16x650-8. I ended up using a wide-jawed Bessy woodworking clamp to break the bead loose, then a pry bar, along with several big screw drivers to slowly work the tire off the wheel. I tried the vise trick described on this web page (yes, you can find anything on the internet), but it didn't really work, but I'll post it here in case you have better luck with it. The hard part was holding down the tire while you are working on it, so having a second person really helps. Hope this helps a little.
Actually, if you use Mr. Google and type in the title given below, quite a few hits show up.
Jim
How To Remove a Lawnmower Tire from the Rim
If it is just flat Slime it
Dustmaker Mike
>Yup Slime it and the rest of the tires on the tractor and wheel barrel and carts etc. I use slime on all my small tires and have not had a flat since I started doing it. Before I started I used to have at least one flat tire a month because of the black berry bushes I was tearing out.
Fred Davis
>For those with Terrain that gives them flats on a regular basis , like our place which has iron coming up all of the the time, especially before we got a good lawn going.
Don's tires in Abilene , injected my Bobcat's tires with rigid foam and a year later did my John Deere riding mower and no flats in seven years. Rides like a lumber wagon now , but who cares ;-))
FredD
Rob Sandow
>Take it to a local shop and have them put a tube in it. It's well worth the cost. I had problems with all my tractor tires until I did this. Since then, no problems.
>Breaking the bead wasn't a problem for me. The tire kept loosing air so I let the rest out and then drove it around the yard for few minutes. Came loose very quickly. I put soap on the rim. What I couldn't do was get it inflated. I wrapped 2 band clamps around it and tightened them until the bead seated. then inflated it. It still leaked so I just took the tire to the lawn mower place and had him put a tube in.
Amazing stuff
Tony - Memphis
>I tried some of the green slime from Lowes or HD and it fixed my wheelbarrow. I haven't had a flat in a few years. Used to, it would leak down very often and then just stay flat. Nice to find something that works once in a while.
Tony
Re: OT: Mine came loose 2 yrs ago
Brian in Brighton
>I tried and tried, but ended up taking it to the local tire shop and they were able to get the bead to seat again and fill it up. I left my man-card on the table and slinked away.
If you find a cool way, let us know.
Brian in Brighton
