Shaker Style Tables,Chapter 5
Andy Lincoln,in Dearborn MI
>Hi All,
I am continuing my process in making a set of shaker tables. As time for the wedding draws ever closer (Saturday the 12th of Sept.) I am concentrating on the two tables made of Red Elm. The steps involved in the other tables are the same, with the exception of the finishes. I am not sure yet what those will be. On the tables made of Red Elm the finish will be an water-based aniline dye in a med. brown with several hand rubbed coats of Waterlox wiping varnish.
I began this segment by milling the stock for all the tops and gluing those boards into larger pieces to make the 18�x 18� tops.
| From Shaker Style End Tables |
After all the wood was glued up I was able to run the stock through a Delta 18/36 Drum sander, which is quite helpful in getting nice smooth panels.
This panel happens to be made of Walnut.
While the glue was drying on the tabletops I set up my router to mill the half-blind dovetails into the drawer faces. This set-up uses a �� template guide bushing in the router as well as a homemade template to cut the half blind pins in the drawer face stock. This is based on an article in Popular Woodworking by Troy Sexton entitled $19.99 Dovetail Jig. I found it to be a simple, effective way to cut these joints without a lot of expense or complicated jigs. I happened to have the template available from a previous project, a pair of Walnut tables I built for my wife, that is the same size as needed so I spent no time making another.
Here you can see the results of the router work:
I then hand cut the tails on my poplar drawer stock and fitted those to the drawer fronts. Although they are not perfect by any means they do look somewhat better that the dovetails I used to join the top rail.
Here are the tables with the drawers fitted and ready for finishing. In some of the photos the wood is wet. I am pre-raising the grain and will knock the nibs down with sandpaper before applying the dye. I am doing this write-up while waiting for the water to dry.
I would have liked to take more photos of the drawer construction but for these two tables the looming deadline is approaching. I can possibly document the drawer construction when I head back into the shop to work on the other 6 tables.
Thanks For Looking,
Andy
