New shop setup
New shop setup
New shop setup
Tom Dunlap
>I've fallen into a fantastic situation! Free shop space!
Friends of mine have a room at their shop where I'll be able to setup my wood and metal working tools. The 'rent' will be paid by letting them use my tools. Both of the guys take care of their gear and we all trust each other.
Their shop is made from concrete blocks which have been painted. The paint is a bit thin so we're going to start by painting the walls. Is there really any need to use 'block fill'? I know...the 100% right way would be to use a sealing primer but I'm thinking that whatever paint is there will act as a 'good-enough' primer.
The 8' florescent fixtures will be tested and cleaned. Moving them down and adding reflectors will help a lot too.
Next in order will be adding wiring.
Then...time to make sawdust!
Thanks for any painting pointers.
Tom
Re: New shop setup
Re: New shop setup
>Tom, I think Block fill is a good idea. Most blocks are only about 95% solid with lots of tiny voids. I have been on commercial construction sites with long tall walls and you could actually feel the winds coming through the walls. OTOH, if it is for color only and you don't care, neither do I. Congrats on the new shop.
Re: New shop setup
Re: New shop setup
Tom Dunlap
>The reason for painting is to brighten the shop. I don't want to have to paint two more layers on the block walls. It seems to me that the existing layer would act like a sealer or primer. This layer will just brighten things up.
In time we're likely to hang tool racks and salvage cabinets up.
The Habitat for Humanity Re-Use store is in the next block so we will have all of the cheap goodies needed to outfit the shop.
This week I'm going to Re-Use and to the city recycling center to see if I can pick up some cast-off paint to use.
Re: New shop setup
Re: New shop setup
Stuart Hough
>Tom, one thing to consider with a concrete block shop, have plenty of things on the walls (i.e. cabinets, fixtures, or even hang movers blankets). The reflected sound reverberating back and forth can be deafening without something to absorb or break up the sound waves. just my 2 cents worth.
