$25 off $149 or more spent at HD
Dan Mitchell
>After getting input here and elsewhere on the Ridgid oscillating drum/belt sander, this afternoon I went to the local Home Depot to pick one up. $199. To my surprise though, when they rung the tool up, I was only charged $174! Seems they're having a not-too-terribly-well-publicized sale where you get 25 bucks off any purchase over $149. Wasn't even mentioned on their web site when I looked there this morning "just in case" they had any coupons, etc. A great tool, at ~13% off. Can't wait to fire it up!
Dan
Re: $25 off $149 or more spent at HD
couple thing's about the RIDGID unit
del schisler
>the only thing to do is take the nut's off that hold the belt unit on and not tighten it to tight If you do You will not get it off The nut just has to be just snug not real tight I had my first one and the nut some how got real tight and couldn't get it off I used a pipe wrench and still couldn't get it off I took it back and got a new machine The same way when you tighten the drum not to tight just tight enough so the drum soesn't spin on the spendle Other than that it is ok for the amount of money it cost's Another thing when you use the belt to streighten out a 4" piece the back on the right side watch out it will cup out the end good luck
Thanks for the tips.
Dan Mitchell
>Haven't tried the belt yet, but I used the sander yesterday with the 2" drum. One thing I noticed when using the drum is that the plastic throat plate is not as rigid (Ridgid ? ;-) as I would like. If you're not careful, you end up pushing it down with the work piece & sanding unevenly. May try making a replacement out of Ash.
Some people have commented online about having a hard time finding drums & belts. Have you found this to be the case?
Dan
Eric Murphy - Spring TX
>The HD deal you're talking about is actually in the advert from last Thursday and again in this SUnday's paper. It isn't $25 of $149 on anything in the store, it is specific to tool purchases. It is a tiered sale...$25 off $149-$299, $75 off $300-$599, $150 off $600-$999, $300 off $1000+. For more details, go to the HD website, click on weekly ads and look at the ad from Thursday, Sept. 3 on page 9.
Re: Thanks for the tips.
del schisler
>the belts are standard 3x21 The drum's last a long time unless you use wood with lot's of pitch Than you can clean them I have found that mine is ok as far as bending somewhat Maybe pushing a little bit to hard to the drum I have used it a lot and dont remember any problum Some of the sponsers may stock sanding drum's No other thing's Just set up the bench square to the belt I used a square and found that to be close enough We aren't sanding for a glue up
