Totally OT ever have one of those days? ;-) *LINK*
Dan Donaldson
>Fast connection needed
One of those days
Dan Donaldson
One of those days
Is there any other kind of day?
Forrest Addy
Amen to that one, brother!
Stuart Hough
Older ain't always wiser
Doug Ridley
>I use a flap sander on a motor shaft to clean up my Cypress knees before carving. Lately the motor has been knocking the waddin' out of me every time my hand happened to brush it as I was sanding. Nothing but static electricity. Didn't used to do this. I finally decided to do something about it and hooked up a ground wire to the ground wire in the switch. Tried it again and wham! So I thought I would do a better job and spent the morning drilling a hole in the wall, drove a pipe in th ground and attached a ground wire from the motor to the ground. Now I knew I wouldn't have to keep getting shocked. Tried it again and wham! Wife said have you tried it with the rubber mat you were standing on removed? Bingo! I had recently put down that mat where I stand. I thought of getting out of the car in the winter and getting shocked. The static electricity wasn't from the motor, It was building up in me! Moved the mat and problem solved. No more build-up.
Moral-- Ask your wife and there is no way to fix stupid.
Older ain't always wiser.
Re: Surprising we've made it this far
Brian in Brighton
You could have
>attached a ground wire to your sneakers instead of removing the mat.
