OT: Help with fixing sidewalk
Dominic in Buck's County PA
>Hi everyone,
I'd like to draw on the collective wisdom here and see if I can solve this water drainage problem I have.
The sidewalk that runs along the length of my garage and leads to it's side entrance door has (through time) sloped back towards the garage. As you can see in the photo, there is a downspout coming off of the house and during times of heavy rain it will provide a nice deluge which is promptly channeled into my shop. The water comes under the threshold-less door. But it also will work it's way under the sill plate.
Photobucket
Photobucket
The concrete walkway was poured as (2) large slabs by the previous owner. Each slab has a control joint that bisects it. Normally I would simply use a long pry bar and lift the slabs so that I could add sand underneath them and address their negative slope. However, other than a small amount of space at the door, I don't have a lot of room to insert that pry bar. And the sidewalk is bracketed on one side by the concrete patio slab, and on the other side by the garage.
I've been giving some though to using a stone chisel to crack the slab at the control joint. Since that will cut the slab into two, it MIGHT make it easier for me to raise it. I could theoretically move one of the slabs out of the way and them work on the rest.
Before I do this I'd like to know if anyone else have other suggestions?
In addition to this I'd like to seal some gaps between the concrete sidewalk and the garage slab. These are wide open and provide a nice little trench for water to collect. This gap was probably where the water originally got in and washed away the footing from underneath. I need a way to seal this. I've heard there is a flexible caulk that is used to do just this. Can someone provide more information on this? I've gone online and searched for "sidewalk repair" but the methods vary greatly from one to another.
I'd really like to get this resolved before the weather turns cold. That way I can install a new door with a threshold and do some needed repairs to the rest of the garage. But before I do them, I need to stop the water from getting in there!
Thanks in advance!
See ya around,
Dominic
Re: OT: Help with fixing sidewalk
Gene DiNardo
>Dom,
There is a method called hydraulic slab jacking.
A couple of small holes are drilled through the slab at the low end, and cementatous cement slurry is pumped in under pressure.
This lifts the low end a couple of inches and cures in place.
There is a limit to how high it can lift but, I think in your case,
an inch or two will do.
Of course there is always the risk of the slab cracking but, it's pretty cheap to do and the alternative is to break up the slab anyway. I think a job that size would only be a couple hundred bucks.
It's worth a try.
Also, there is a product for sealing the joints (I cant think of the name off the top of my head) it is a two part concrete epoxy caulk.
It requires a two barrel caulk gun (available from the product manufacturer). I'll try to find it in my shed tomorrow and get you the name.
Gene
2nd vote for mud-jacking
Bruce, a MN Galoot
>We had that done with part of our driveway and a significant chunk of sidewalk at our last house. It works really well.
Bruce
Jesper, Denmark
Jesper, Denmark
>Hi Domom,
It looks like a more basic problem than the sidewalk. If I look at the bottom picture, the shop fllor looks like it is quite a bit lower than the slab on the left. No amount of fixing the slab will change that. If the picture shows the true situation and the slab and gate bottom are level, the shop floor looks like it is 2 inches lower than the slab.
I would start by measuring the difference in elevation between the slab and the shop foor. If you can confirm the shop is lower, then you should probably install a covered trench in the sidewalk with a perforated metal cover and lead the water away to some lower ground.
Hamish
>Hi Dominic,
What you should be looking at to solve the problem is to make sure that the rain water does not run or reach the join between the garage wall and the concrete path. A quick cheep solution is to cement a line of bricks, one course high and on their side, along the path next to the garage wall. Finish them off by making a semi circular join with the tip of your trowel in the mortar between the brick and the path. Once everything is dry, you could then run a bead of flexible sealing chalk between the garage wall and the top of the bricks.
Where your entrance door is, you would need to continue the run of bricks across it and build up your threshold to the same height. As a further precaution, put a wooden drip (a strip of wood, 2 or 3 in wide, that slopes downwards, onto the garage door, in such a way that it just clears the to of the bricks. Thus rain water will be directed away from the building.
A second solution would be to break up all the path and re-do it, I wouldn't bother about jacking it up-too much hassle, so that it slopes away from your garage. Bear in mind the height of the patio on the far LHS in the lower picture. You would need to raise your threshold too and probably shape the edge of the concrete upwards as it nears the garage wall, to add a similar effect to the bricks as mentioned above. Anything to keep the water away, especially when it rains hard.
I hope this will give you some ideas.
Cheers, Hamish.
Dominic Greco in Bucks County Pa
>Thanks for the input. The pics may be bit misleading due to the angle they were shot at. The sidewalk is actually a bit LOWER than the garage slab
>Dominic,
As a Home Inspector is see things like this frequently.
Let me give you the Kindergarten Primer on leaks. Every leak has three parts. For anything to leak, there must be ALL three of the following. A Hole for the water to pass through, a "driving" force that makes the water go through the hole, and Water. Eliminate anyone of the three and the problem goes away.
Gene's suggestion of mud jacking is an attempt to take away the water by making the driving force work for you. Slope the slab away from the garage and hopefully gravity will carry the water away.
Hamish's suggestion of the bricks and wooden drip cap is an attempt to seal the hole. If there is no hole, the water can not get in.
In both cases there remain some questions. In either case, where would the water go? If you jack up the existing slab (or replace it with a new one) would it just be shifted out from the garage the width of the slab and then stand there in a puddle? With the brick sill, would there just be a puddle standing be side the sill? In Bucks County you surely get freezing weather. Any puddles would turn into sheets of ice.
It appears to me that either the slab was poured wrong to begin with or it settled next to the garage. The slab should have had about an inch or more of slope away from the garage. The vinyl siding may have been put on after the slab settled, but there does not appear to be enough room under it to raise the slab enough to create the slope needed to jack the slab enough to do the job. If the siding is at the bottom of the wall, If you raise the siding and the slab, the bottom sill will be directly beside the edge of the slab. Hope it is treated wood. (of course, it is getting wet in every heavy rain now, so that may be a moot point.)
If you raise the garage side of the slab, the garage slab may end up lower than the edge of the slab. You could install a door sill to "cover" that. If the water flows away this might work well in that it may only leak in torrential wind driven rains.
The problem with installing the sill as Hamish suggests is that it is very difficult to bond new masonry to existing masonry. The new materials would separate and leak in fairly short order because of Freeze thaw cycles.
So, maybe the first step is to see where the water needs to go to permanently send it on its way. Then what do you need to do to send the water there immediately.
Jack up the slab or replace it with a new one sloping away from the garage and toward the destination. This may require removing and reinstalling the bottom course of siding. IF that is vinyl siding, that is easy. (Not so easy with aluminum siding) You may also need a door sill.
Look at that down spout and see if you can put an extension on it and send the water further away. Or perhaps move the downspout to a different location.
There are excellent caulks that may help AFTER you make the substantial changes to send the water away. Some are made by Companies like Thiokol or Pecora. Check with a swimming pool company about what they use around concrete pool deck. It may be possible to insert a piece of flashing into the crack between the house and the garage to help keep water from wicking into the bottom plate and up the wall.
If it were mine....
Kneale Brownson..Awaiting return to CO snows
>I'd break up the concrete, install a drain pit along the edge of the building with a steel grille, install a drain carrying water away from the pit and redo the rest of the walk/drive area with new concrete sloping away from the pit.
Fred Davis
>I ran across similar problems like yours when I was contracting Dominic and yours is about typical.
I cannot see beyond the gate in your picture , so I don't know where the sidewalk ends .
The fix is two part if the drive slab allows it.
First have a sheet metal/gutter shop relocate the main source of the the problem, namely the down spout.
Secondly , I would remove the sidewalk slab and pour a new one , making sure that the new one sloped about a inch from the high end towards the low end of your garage.
This will cause a discrepancy in adjacent heights, between the patio slab and the sidewalk , but that isn't near the problem you now have.
If that siding is wood get it a inch above the cement.
When you have the new trench open prior to pouring the sidewalk, install a metal flashing about six inches wide , that will be under the siding and extend down into the trench , making a water tight seal at that junction of the sidewalk and the wall.
Your doorway shouldn't need a new sill at this point , unless driving rain can get under the door. Hope this helps.
A covered walkway help alot also.
FredD
>Thanks for all the suggestions everyone.
Rerouting the down spouts is a nice idea but impossible for that area. That is a short section of roof that has no where else to drain. Unless I put the down spout right in the middle of my sliding glass doors!
My wife and I decided before this to replace the (poorly laid) cement with bricks. And when we do, I planned on installing som flashing along the base of the garage.
But that project will have to wait until next year. I was looking for a quick fix that will get me through the next couple seasons.
Then I would mud jack.
Dan Donaldson
Also
Dan Donaldson
>When you replace the cement, run the gutter into a pipe under the sidewalk to a small catch basin out in the yard somewhere. I have one like that and it really helps to keep the water away from the house.. Relatively cheap to do and it will save a lot of hassle later.
GalenV in Iowa
>Since you cannot relocate the downspout can you at least remove the splash block and add a short horizontal section of downspout with say a 45 elbow to direct the water away from your air conditioning unit and the garage?
If that slab has some slope hopefully it will carry the water away from the garage till you do the new walk.
Looks like the splash block allows the water to go towards the walk from the staining that is there.
Fred Davis
>What is on the other end of the gutter.
If it has a clear space to run down a new down spout, remove the old one and plug the hole .
FredD
Re: Also
>That's EXACTLY what I planned to do! I need to do this for my sump pump as well.
>That gutter is about 4' to 5' long. The other end is over the AC unit and in the middle of the concrete patio. So moving/rerouting it is not an option at this time.
Re: Also------WebKitFormBoundaryDA7LYGi+nrOacJTc
John in Calgary------WebKitFormBoundaryDA7LYGi+nrO
>Just remember to leave some space between the bottom of the drain spout and the top of the underground pipe - in the winter time when temperatures hover around freezing, sun can melt snow build up off the roof, which freezes the moment it hits the underground portion causing the water to drain right down the side of the house. Many, many folk have tried routing their drains away underground in Calgary, only to have the underground portion freeze solid and the water ends up backing up into their basements.
John
