I need a band saw fence.....
Bill Tindall, E.TN
>....for a 20: Delta band saw. I have been using a home made install with C-clamp fence and it is fine for resawing. But I would like to use the saw for ripping, as an alternative to the table saw, so a conveniently adjustable fence (like on a table saw) is essential. So, where and what to get for a fence?
Re: I need a band saw fence.....
Glenn Madsen near San Francisco------WebKitFormBou
>I cobbled a Kreg bandsaw fence onto a Jet 16 some years back. It sorta worked. Wasn't really long enough, but I bolted an extension on, which helped. The biggest problem was taking everything apart to change the blade, which happened more often than I wanted.
What does your home made one not do?
E bay
Virgil Johnson
>I just scanned e bay and found several after market fences that could possibly be rigged to fit your saw.
wilbur
>HI Bill,
Two other options:
1. Go to www.owwm.org, which is the forum for owwm.com, and put a "WTB: Delta 20" bandsaw fence" post in their "Bring Out Your Dead" board. There's a decent chance that someone there will have one.
2. Carter just came out with a magnetic fence. I haven't seen it yet, but it seems like an easy way to retrofit a bandsaw fence.
http://www.carterproducts.com/product_list.asp?cat_id=75
Re: I need a band saw fence..... *LINK*
Dave Paine
>My Grizzly 17in Bandsaw has a decent fence. See link.
A less expensive solution is a flat clamp also called Edge clamp. I can only add one URL, but search for Grizzly H9981 24 in edge clamp.I use one when I need to rip a width less than distance from left side of upper bearing support and want to have upper bearing support lower than height of fence. You could always glue piece of wood to the edge clamp if you want something taller. Only issue with edge clamp if can only rip to edge of table and not full width of saw.
http://www.grizzly.com/catalog/2009/Main/96
answer
Bill Tindall, E.TN
>adjust for width of cut rapidly
the problem
Bill Tindall, E.TN
>These fences are for the tiny tables on 14" saws. I need a fence 24" long
I'm looking on Amazon.....
>I have a 14" Delta saw and looking for a fence. Shopping on Amazon to help WoodCentral and to use a credit I have there. I am watching the responses to your post.
Re: the problem *LINK*
Bill Earl
>The Peachtree Woodworking EZ-Square fence is 24 inches long. But you might have to improvise the mounting for the rear-rail runner on a wider table.
Mule Cabinetmaker makes one that appears to be basically the same design, minus the rear rail.
I've been using the Peachtree for a couple of months now and am 100%pleased with it. The rigidity and ease of adjustment are comparable to the Biesemeyer on my TS.
Peachtree EZ-Square
Jesse Cloud
>These days I use a shop made fence with a couple of mag-jigs inset. The 30mm mag jig has plenty of holding power, though I add another 20mm magnet just to be sure. They screw onto your jig. A handle turns the magnet on/off. Easy to make the fence and the height can be exactly what you are looking for.
And super easy to reposition.
Curly Smith
>You could order replacement parts from Delta and build one. This page is for a model 28-641 and, from Page B, it looks like you'd need parts 132-136 for ~$130. If your model isn't listed then one of the other models may use the same table as yours.
This is similar to the Peachtree model previously mentioned Mule Cabinetmaker Bandsaw Fences
As another option, the length of the band saw top may be very similar to that of a benchtop or portable table saw. For instance, the Bosch 4100DG-09 has a top that measures 21.5" x 29.0" (the Shopsmith is 22") and it might be fairly simple to fit the rails to your band saw. And, there are always a bunch of small table saws for sale on Craigslist for less than $100...
Re: thanks for helpful suggestions
Art Liebeskind
>I just bought a Laguna "Driftmaster". Expensiove but fabulous. Look on Laguna website.
Art Liebeskind
I second that!
Ken Garlock, Collin County Texas
>I installed the drift master and it is a joy to use.
I bought the drift master when it was on on sale for 275 at Amazon. It is now 325.
Happy sawdust,
Ken
charlie belden
>Here's a link to a DIY table top and fence you can make. You can set the fence to match the drift/lead angle of the bandsaw blade you're using.
I think I got the idea from a resawing article in an issue of Woodworking Journal or American Woodworker.
DIY table top and fence set up
