plugging 220v 15A into a 220v 30A socket
Simon St.Laurent - Dryden, NY
>I have a jointer that uses a smallish 15A/250V plug, NEMA 6-15P, and plugs into a NEMA 6-15R receptacle. In my shop-planning non-brilliance, the plug is badly located for working with long stock, so I'd like to temporarily move the jointer to a different location in my basement.
The receptacle there, though, is on a huge 30A circuit and uses a NEMA 6-30R socket. I don't think there should be a problem running the smaller device on the bigger circuit - definitely let me know if I'm wrong. However, I'm not finding an adapter to do that.
I'd rather not rewire the plug for this particular project, though if that's what's necessary in the long run, I certainly can.
Any advice on where to find such adapters? What I'm finding seems to be either international plug adapters or RV/boat applications, all of which use different kinds of plugs.
(Boy, was I happy to find this plug reference after about 20 minutes wandering through infinite different 220V plugs....)
Re: plugging 220v 15A into a 220v 30A socket
Rod Peterson -- Ormond Beach
>Electrically, there is no problem running your jointer on the 30A circuit. It's exactly analogous to plugging your phone charger (which draws milliamps) into the 20A kitchen circuit. Volts is volts, and although the larger circuit can supply as much as 30A, it will only deliver what the jointer draws. This is a fundamental of electricity that a lot of web posters don't get.
And it's absolutely no different than if your jointer drew a mere 10 or 12 amps and could run on a 15A circuit, but was plugged into a 20A circuit (which is possible because of the dual polarity nature of the NEMA 6-20R configuration). And don't think the 6-15 series is electrically limited to 15A—it's polarized to prevent a 20A device from being plugged into a 15A circuit.
Down to cases, what I would do is make a short jumper (or dongle) with a 6-30P on one end and a 6-15R on the other. Volts is volts, and it's still hot to hot, hot to hot, ground to ground on the wiring. Note that at 240V, it doesn't matter which hot you connect to which hot, consequently even cord with black & white conductors will work just as well as the traditional black & red common with 240V wiring. I also would use the kind of jacketed cord as used in extension cords (and I'd use 12 gauge)—not non-metallic cable (Romex).
A tip: I would make the jumper long enough so the plug/receptacle junction will lay on the floor, relieving some stress on the plug in the wall receptacle.
All the foregoing is with regard to the specific query of running your 240V jointer fitted with a NEMA 6-15R plug on a 30A 240V circuit with a 6-30R receptacle. Safe? Yes. Legal? Possibly not. Risk of burning down your house/shop as a result? Zero.
Rod
Addy Protocol: experienced amateur electrician
What he said....exactly what I thought.
Howard Acheson
Just buy a new 30 amp 240 volt plug that mates with the 30 amp receptacle. There is no problem whatsoever.
>Thanks - I'm trying to avoid rewiring the jointer plug because this is hopefully just a temporary move, but I'll definitely keep that in mind if it becomes permanent!
jumper sounds good!
>I was hoping such dongles already existed, but this is definitely within my limited electrical tinkering capabilities.
I hope it will only see brief use, until I can rearrange things, but it'll be helpful in any event.
Thanks!
