Glue Recommendation
Jerry Draper
>What would be the best glue to use on an outdoor project made of Red Cedar?
Glue Recommendation
Jerry Draper
Re: Glue Recommendation
Grant in Iowa
>Jerry,
Tell us more about the project, and what you expect the glue to fasten to what (load wise, material, climate), and we'll give you more options or help narrow it down. Here are some quick choices:
If you want life of the wood durability, then Resorcinol is a great choice. This is the purplish black stuff you see on exterior plywood. It is known to be reasonably heat tolerant and totally waterproof. Down side is the short pot life (it is a two part glue), and the reddish black color. Also can be expensive, since you will likely have to mail order it.
If you want a home center choice, then Titebond 3 will likely meet your needs. Goes on like woodorking glue, but is very water resistant. Gorilla glue is also a decent option of those available at home centers.
There are also contractor type choices such as the Liquid Nails line (check the caulking aisle). Might be a good choice if you need a lot of glue.
Epoxy comes to mind as well, but it has long term UV resistant issues, as well as not holding up above 120 degrees very well.
If you will be putting a film finish on your project, then consider Dap Weldwood Acrylic Resin. Often used for structural joints where appearance is immportant. I believe this needs the protection of a finish over it, however. Big benefit is the long pot life and short set up time (if you control the temperature). Says on the container "for interior use", but it has been used for decades outdoors with no issues.
Again, tell us more and we'll give you more options.
Regards,
Grant in Iowa
Jerry Draper
>Making bird houses for neighbors. Year round exposures varing from 98 degrees F. to 15 degrees F. I am concerned about edge joined boards seperating over time.
howard
>I made a few cedar beches many years ago and used polyurethane glue (Gorilla or any other brand that makes it). The benches are still holding strong. Edge joints will not fail as long as they are jointed well. Once glued up, the would next to the glue joint will break first before the joint itself.
Thank you.
Jerry Draper
Jesper, Denmark
>Screw and nail. No glue.
The birds don't care about a few cracks and the neigbors won't see it.
Glue is just complicating the project.
mdclor
>Also, I have been told that hatchlings can be sensitive to any fumes given off by the glue. FWIW.
get a pin nailer
del schisler
>use a pin nailer than maybe a dab of glue in a few spot's To make it solid Or just nail it Brother build's bird houses and use's a pin nailer only
Marv
>Jerry,
Epoxy adhesives will work. Once they cure, there will be no continuing outgassing.
Marv
