Veritas - Innovation in Tools
Round-over Bit Sizing
Doug Reynolds in Seattle
>Plans call for specific round-over profiles on molding. How can I easily determine the size of round-over router bits? If I need a 1/4" round-over, can I take a 1/4" drill bit and see if it matches the router bit profile exactly or, do I use a 1/2" drill bit? And, so on. TIA.
Re: Round-over Bit Sizing
Lee Schierer - McKean, PA
>Typically when a plan calls for a roundover, they are referring to a radius and roundover router bits are typically sized by radius as well. Using a drill bit would help you visualize the curvature and could be used to select which bit to use. Another option would be to make a storage rack and label the holes for the shanks with the radius size.
Lee
Jesper, Denmark
Jesper, Denmark
>Round-over bits are sized by radius, so you would use a � inch drill bit.
Fred Davis
