Veritas - Innovation in Tools
OT Cooktop Repair
OT Cooktop Repair
OT Cooktop Repair
Sawman
>I have a GE cooktop,gas, that needs a new sparking unit.
I cannot ssem to get the top off after removing the screwss that are in the burners.
Anyone have any experience with these?
Thanks
Re: OT Cooktop Repair
I just did this repair
Nat Robison
>I have a GE gas cooktop and just replaced a spark switch about a week ago. Once you remove the 2 screws per burner, carefully try to pry up the burner pans. Once the pans are out, you should be able to lift off the tempered glass part of it. It might be stuck somewhat to the foam gasket that's between the glass and countertop, but it will separate. The burner pans might also be a bit reluctant but they'll separate as well.
