Splitter options?
Splitter options?
Splitter options?
Edward in Vancouver
>Happened again tonight. Was ripping stock and the wimpy splitter bent and forced my cut away from the blade.
It's a 2 yr old Delta Contractor's saw, motor hanging out the back. I always use the splitter for ripping--took off the (delated) clear plastic guard, but the splitter does do a decent job--when it works. Pawls are useless--recycled beer cans, though.
I did get one of those plastic tab thingees that you put into the throat plate--but--caveat here-- the plastic splitter's accuaracy is dependant on the fit of the throat plate. If the throat plate moves, the little plastic tab/splitter doesn't do it's job.
I'm ready to fork out up to $150 for decent aftermarket splitter.
Suggestions anyone?
Re: Splitter options?
>Gopopd Morning Edward,
I regret selling my Jet blue contractor saw for a couple reasons, one being the Zero Clearance Insert(ZCI)/splitter arrangerment. I threw the blade guard on the wall, and made my own ZCIs which I later modified to accept glued in/on wood splitter tabs. The ZCI design configuration permitted me to kerf a slot long enough for a splitter tab to be installed using yellow glue. The ZCIs were well fit to the table and didn't shift, so the splitter was truely aligned. I suggest you try to make your own. After a mistake or two, I got fine results, and made ZCI's w/splitters for every blade I own.
George
I have the same saw - love the Bies splitter *LINK*
Tim Greif - West of Chicago
>I gave up on the stock splitter on my Delta CS almost immediately. I love the convenience of the Biesemeyer snap-in. But it's pretty spendy. Although, I don't regret it at all. I removed the kickback pawls on it though.
Splitter for Delta Contractor Saw
Tony - Memphis
>I had the Bies on my Delta, but it was for a standard blade and I got a thin kerf. I made my own splitter out of masonite sticking out of a shop made throat plate. It worked very well and was easy to make. The Bies was a nice piece. Pretty solid and was easy to remove when needed.
Tony
Re: I have the same saw - love the Bies splitter--
Glenn Madsen near San Francisco------WebKitFormBou
>I bought my Unisaw about 2002, iirc. The stock arrangement got sent off to someone who wanted one.
There is, or was, a removable splitter Delta sold, part of their big tube mounted system. The local Rockler guys got it for me for maybe $32 plus tax. Something cheap. It works and gets used a lot. And looks very similar to that one shown in the previous post, except that the base differs some.
Those are well engineered, if they fit your saw.
------WebKitFormBoundary+8T1zm4STb5aZP8r
Re: Here's a link
Edward in Vancouver
>Quite a thread, lots to think about. I'll check out the Bies, and there's a store here in Vancouver that repairs Delata/PC, and sells most of the associated stuff.
The option of making my own looks simple enough--that is a hunk of steel bolted to the trunion cage where the original splitter was.
Don't know about Delta CS's in the US, but here they all come standard with a tab cast on the rim of where the plate sits that is drilled and tapped, the throat plate can be screwed down. The micro-jig and all other home made style "splitters" rely on tight fitting throat plates, or the whole deal will shift. I've made the usual assortment of wood throat plates (my favorite being oak flooring off-cuts---perfect thickness and shiny smooth to boot) but try as I might, either I never get a "just right" fitting plate, or it's too tight and I need a screwdriver and 10 minutes to pry the thing out when I want to change blades.
Thanks for the replies
Tony - Memphis
>Edward, after reading your post, I thought maybe I had kept the Beis splitter. I dug around in the shop last night and found it. Its yours if you want it. Just let me know. I'd muchn rather you use it than it sit in my shop and collect dust. Not sure how hard it is to ship to your neck of the woods, but I work for a large shipping company, so maybe I can figure it out. I brought it into work with me, so I could ship it out today if you want. I don't check this email address often, so let me know here if you send me an email. I don't like to post my work address online.
Tony
