Waterski, Serial #1
Grant in Iowa
>About three years ago I had a good long look at the wooden waterskis our local show ski team uses to pull off their stunts. They looked fairly simple to build, so I mentioned that I might be able to build some for the team.
First, I studied bentwood laminations,epoxies, glues, finishes, and everything in between. Probably the longest delay in the project was stopping to build a house in there somewhere.
Pictured below is Serial #1, a prototype that was ridden upon last evening for the first time by three impressed skiers.
The ski is made of three 1/4" thick resawn layers taken from ash blanks, clamped to the form in a vacuum press. I used DAP Weldwood Plastic resin glue, at the recommendation of a 60 year veteran of waterski building.
The ski has four coats of Helmsman spar urethane finish brushed on and sanded lightly between coats.
This particular ski is wider than most recreational skis because it is designed to be a wide, stable platform for a line of girls doing "chorus girl" type movements on the water. The skiers only criticism was related to the positioning of the binding, so I did pretty well with "Old #1"!
The production versions will likely be laminated top and bottom with Formica for durability. The fins will be made of 3/4" HDPE instead of the pictured ash.
Regards,
Grant in Iowa
