Re: EIDE Cable
Dave Paine
>I second the test of the cable. ALso agree to remove the power to the PC. Many components are powered even if the computer is off, unless the power cable to the PC is removed.
I have experienced the internal power or controller cables to go bad over time. First to test is the controller cable.
If these are ATA cables, it will be long flat cable. These have tiny connections, and easy to lose one of the many connections resulting in unit not working.
Power connection in normally 4 wire. Try using another spare connection.
If all testing fails, then fall back is to try and find a geek, or an old geezer, such as myself who has been fixing this stuff for decades.
I hope this is not the motherboard controller which has failed. Replacing motherboard is major hassle, since many compoents on present system may not work with a new motherboard.
Last December I had a motherboard failure. I had to get new motherboard, which meant new CPU, new memory, new DVD, due to new motherboard having too few ATA connectors. New standard is SATA. I like smaller cables for SATA, but it was a pain to need to throw away other hardware which worked in previous motherboard, just due to connection standard changes.
