Bathroom Vanity Sink
Richard Krieger
>Little out of my real element here but would like some opinions. Making a small bathroom vanity with a MAXIMUM counter top DEPTH of 22" including overhang. Question: Does anyone know if you can purchase an "under-mount" oval sink small enough to accommodate a set of faucets behind sink next to backsplash. SWMBO will not allow a sink on which the faucet could mount. Must be a separate under-mounted oval sink with a separate faucet set. Any help, sources or advice whether this will work or not would be appreciated. Have been to some "box" stores and most oval's are bigger than that.
Thanks
Re: Bathroom Vanity Sink
Fred Davis
>Here you go , a vanity in our masterbath, custom cast in Onyx by a Marble caster.
standard 22" depth.
FredD
Richard Krieger
>Thanks, Fred.......That will help her see what it's like.
Appreciate it.
Check with a plumbing supplier
>I've noticed that big box stores have a severely limited selection of bathroom fixtures, and most are available in white or almond. I suppose they have special order capabilities, but I've had better luck shopping at a real plumbing supply distributor showroom.
Re: Different approach
Kneale Brownson..Awaiting return to CO snows
>I don't like little sinks. I've made several small bathrooms slightly more spacious by removing a couple studs and setting larger sinks--and their vanities-- part way into the wall.
But, like Ellis says, you'll find a greater range of choices at real plumber supply stores.
Can't help on the undermount question
>because I've never looked at one.
I will comment, though, that in severe space crunchy situations, I've seen some installations with the faucets mounted off to the side (at about 45 degrees to the back). Not the best layout, but it works; at one point, I was considering it for our currently planned bath remodel, until we changed the bath layout.
Fred Davis
>Richard ,
you can check plumbing supplies and never find a seamless approach to vanity sinks.
What you will find is various versions of top mounted, undermount, none seamless and therefore not nearly as sanitary or easy to clean as a cast integral sink will be.
That said , wherever you live has a marble caster , they do cast marble , cast Onyx, some do engineered fake stone, but all do integral, seamless casting, in many attractive forms and sizes.
Many have tops already done that people didn't like or didn't pay for , that may fit your needs.
Since Vanity tops are standardized in depth, you see a lot of 22" deep tops.
Big box stores stock a variety of precast tops , that may fit your Vanity, but if they have to order one , go directly to a Marble caster, it's faster , cheaper and less mistake prone.
FredD
