Have a question? Ask Woody!
EPOXY
EPOXY
EPOXY
Marty Rose
>Ok what am I doing wrong? I am trying to use epoxy for the first time. I add the two parts together,trying to get the same amount of each. It took one week for the first to cure. Added more hardener the second time and it took five days to harden. I then purchased the plunger type of epoxy, and it has been three days so far. Still sticky. I've gotten wood glue, and CA down pat, but I am thrown for a loop with epoxy. Any Help would be appreciated
Re: EPOXY
Are you mixing well?
Stephen Roth
>Should set up in a few hours at most.
Re: EPOXY
Re: EPOXY
del schisler
>Make sure you mix sture very well a 2 or 3 min won't be to long I have poured gal's of this stuff Never had any problums Did you brake the bubble's ? I used my torch and very lighty over the top and not to close maybe 6" and back and forth you will see the bubbles break If you didn't do that Could be one reason for not curring It should be hard over nite Ready to sand If still stickey Maybe old stuff Mix a little bit in a plastic or lid and see if it got's hot if not than something wrong with probley the hardner it will get real hot to the touch Maybe 5 min's it will be hot If you get it working right It is very good stuff to work with The only stuff that will clean your brush is hand cleaner Nothing else that i know of And to get it off your hand's also hand cleaner Any else you want to know ??
Re: EPOXY
Re: EPOXY *LINK*
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Marty. You need to give more information. What brand, what mix ratio does the activator container call for. How do you measure? How long do you mix?
Epoxy requires some heat to kick. If it is too cool, it won't kick until you warm it up.
In cold weather, I usually hold the mixing cups under the hot water tap while it runs around the outside of the cup while I am mixing it. Then if the shop is really cool, I make a sort of tent with a tarp and few strips of wood, then have a small electric space heater blowing into it.
Some brands of epoxy exude a waxy film, called amine blush. Are you sure that is not all you are feeling?
http://www.littlemachineshop.com/products/product_
Re: EPOXY
Re: EPOXY
>I have no idea how that link got on my last post.
Re: EPOXY
Re: EPOXY
Marty Rose
>Well I'll try it again. No it did not get HOT to the touch,and it's 114 in my "Garage-Shop"..116 in the Sun so I don't think it's too cold yet
Re: EPOXY
Re: EPOXY
Kelly Anderson
>I had a similar problem this summer when I tried to fill some holes with epoxy. Some of it got hard and worked fine and some never did get hard. I was using Loctite brand, the kind with two different bottles from Lowe's. I though I used the same amount of each and mixed long enough. I guess I never knew that they had to be that close in volume.
Re: EPOXY
Nice work, Keith
>Slight hijack here. Your link was not to an epoxy info page but to your excellent shop shot on that amazing desk of yours. It reminds me of the treasures that lurk just below the surface here. I'm not at my office right now, but I'd like to update your shop shot with larger photos that really show the detail. I can't recall whether you gave us larger shots to begin with, but I'd be willing to pursue this.
Regarding your hinge formula, I for one would be very interested to hear all about it. Do you think we can assemble an article about it, with photos and drawings to illustrate? Just another thought.
Re: Epoxy. I don't know what to add to your reply. I used to have a glue cabinet, an insulated box with a 25-watt light bulb and a thermostat, that I kept all my glues in. What a blessing that was. Heat might be the answer to the question of curing. I don't know what else it could be besides possibly outdated product or contamination of some sort.
Re: EPOXY
Re: Nice work, Keith
Kneale Brownson..Awaiting return to CO snows
>My guess would be outdated stuff from a borg.
Re: EPOXY
Re: EPOXY
Keith Newton
>Your problem sounds like you didn't mix good enough. If when you stir, you are not constantly scraping the bottom and sides, you can leave areas of just resin or activator in the bottom or around the sides.
When I ma mixing, I try to make sure that the stick is scraping the sides, along the thin edge, then rotate the mixing cup about every ten twirls.
After everything is cured, if you break out the residue left in the mixing cup, any un-hardened resin around the sides or bottom is a symptom of not mixing enough.
Re: EPOXY
Keith Newton
>Ellis, I have no idea how that link got in there, and it is not even what it appears to be.
The link should lead to a source for a little spray mist unit for sharpening, not to shop shots.
You ask I would like to do that, but I am really busy on a project which has a nearly impossible deadline. later, K
Re: EPOXY
Re: Damn! Everytime-
Dave Anderson (PacNW)
>Every time I think I am becoming an accomplished woodworker_____Someone always raises the Bar! Fantastic work Keith !!
Re: EPOXY
An important factor
Marv
>You guys are all using the word Epoxy as if there is only one type. There are hundreds of different epoxies. When you buy the stuff in the twin syringes, it comes with different cure times. In any case, they usually will require a 50/50 mixture. Mixing thoroughly is a must. Some types will get warm or hot in a cup, but when this happens, it's already on it's way to getting hard. Usually too late to do much with it. You need to mix it, and use it before it gets hot. When epoxies get hot like this, it will be fast setting types and shouldn't be mixed in large quantities. Larger quantities that require using a ratio by weight between resin and catalyst is a hole different ball game. These are usually casting resins, not adhesives.
Marv
Re: EPOXY
Re: An important factor
Marty Rose
>Well I'd like thank all of you for the input. I guess I will just keep on sturrrrrring until I get it right. Thanks again.
