Re: Sandpaper Sharpening
Neal in San Jose
>The best sandpaper for this is Aluminum Oxide. Silicon Carbide, the common "wet or dry" paper you find in the paint department at the home centers is a fine product for the purpose it is intended for: sanding paint and wood, but it works poorly or not at all for abrading hardened steel.
Remember that an edge is defined as the intersection of TWO surfaces; thus the back is just as important as the front. You will likely only flatten and hone the back once in the tool's life, so do a good job. You will touch it up every time you sharpen the bevel (bezel), but the heavy lifting need only happen once.
As far as a sequence, it is hard to tell you what grade to start with. That will be dependent on the condition of the tool, and what your ultimate goal is. If the blade has deep rust pits, and it is a finish plane, well, you have a long day ahead of you. If it is a scrub plane blade, almost any edge you are able to produce will likely work O.K. So, start as course as you possibly can bring yourself to. Do ALL the flattening and rust removal with the coarsest grit you have. You may have to start at 60 or 80 if the tool in question is in very poor shape. (This makes a good argument for Lee Valley, Lie Nielson or Hock blades, doesn't it?) If the blade isn't too bad, you might get away starting at 120. I'd recommend that you not skip grits, at least not until you get familiar with the process. I know that's a lot of paper, but it really isn't very costly, in the finer grits you will only need one sheet, and your time is worth a lot. The polishing grades from Lee Valley with the mylar backing and up to 2000 grit (I think, I don't have it in front of me) is remarkable stuff and worth every penny. If you are grinding and grinding and don't feel like you are getting any closer to your goal, drop down to a coarser grit.
