Chess board wood
Chess board wood
Chess board wood
Jeff Ham - Hillsboro, OR
>I am making a chess board and wanted to use ash and walnut for the grid pattern. Before I start cutting will I have any long term effects using these wood species from contraction/expansion?
Better wood combination to use?
Re: Chess board wood
Just a thought - how about showing the end grain?
>Then you wouldn't have to worry about expansion and contraction to any great extent.
Wood movement calulator *LINK*
>Alternatively, you can also lap the pieces.
"Shrinkulator"
Yonak
>A chess board I made out of ash and walnut 35 years ago has not come apart. In my ignorance, I even turned the grains to be perpendicular. I glued the center 36 squares to a plywood substratum, but the remaining squares were glued together, and to the center with nothing but surface bonding. The only thing is : the ash is so porus, I remember having a devil of a time getting the dark walnut dust out of the ash pores (I didn't have an air hose then).
I've made a couple
Bruce, a MN Galoot
>walnut and maple, and walnut and cherry. The pieces were 1/8" thick, glued with titebond to a plywood substrate. One is more than 20 years old and the other is only 2 or 3. Nothing has let go yet. No warping problems with either board.
Woodsmith did an article on a nice one a few years back, if you need some technical pointers.
Bruce
Dan Mitchell
>That's what I was thinking about the Ash, pretty open pore. How about hard maple instead? Saw that they had some on sale at the local Rockler yesterday, though I don't recall the price.
>Good Eveningh Jess,
I made these chess sets in 1997, and saw one of them last evening on my #1 son's wet bar. I used maple and mahogany on his, with squares edge glued, and then glued on ply substrate. No problems with splitting of face grain. The maple and mahogany set is on the left, and it makes for the best presentation after all these years.
I stood and watched my #2 grandson play chess with his uncle Jim, my #2 daughter's husband, realizing neither player was "around" when I gifted the set. It gave me a nice feeling.
George
