OT-Itunes/movies
OT-Itunes/movies
OT-Itunes/movies
Sawman
>I down loaded a movie from Itunes the other day and watched it on my computer monitor.
Is there a way to watch it on my TV?
Re: OT-Itunes/movies
Dave Paine
>It depends on the video output type on the PC, and the video input options on the TV.
Most PC's have VGA output, some have DVI output. Very few have HDMI output.
TV's typically have a mix of inputs, cable/antenna input, RCA composite, Svideo, DVI or HDMI.
Some TV's actually have PC input, mine does, but most do not. So in my case I have VGA cable for video and RCA for audio.
If the PC and TV do not have the same type of output/input, you will need a cable adapter. Many places to find these. You will also need to find a converter. The VGA signal from the PC has different sybchronization than video from DVD/VHS player. Without an adapter the PC VGA output will either not display, be scrambled, or in worse case, may damage the TV.
Do a Google search for PC TV converter. Should get a number of hits.
Re: OT-Itunes/movies------WebKitFormBoundaryHuXmJ8
Hamish------WebKitFormBoundaryHuXmJ8nlv+OKwLIL
>You should be able to buy a cable to connect your computer to the TV, that's if it's one of the new flat screen ones. I regularly connect my laptop this way to show the family the photos I've taken.
Hamish.
Dan Donaldson
>Check your computer and tv to see what inputs are available. My Wife's laptop has an hdmi output and our tv has an input. We use the TV as the screen to video conference with the grandkids all the time.
