OT Electric Usage?
OT Electric Usage?
OT Electric Usage?
Sawman
>OK, so I am trying to calculate usage on different appliances. Would I be correct in saying 1-100watt light bulb that iis on for 10 hours uses 1000 watts? And if electricity cost is $.08 per kilowatt, the cost would be $.08 operate that bulb?
Thanks
Maybe this is simpler that I think but I seem to be having a brain fart!
Re: OT Electric Usage?
DaleLenz
>That is correct. Don't forget to add in you elect. meter charge. Makes my .08/kw charge up to .15 in my metered shop. Should hook up to the house meter, some 300' away.
Michael J Bitetti
>Electric usage is measured in Kw/h or Kilo-Watt/hours so don't forget to factor in the time. Your example is correct except for the "unit" you quoted. Kw is a unit of power whereas Kw/h is that power usage over a period of time. A 1000 watt lamp that is on for 1 hour uses the same amount of power that a 100 watt lamp that is on for 10 hours. A 10 watt lamp would use the same Kw/h if it is on for 100 hours, etc.
Mike
Glenn Madsen near San Francisco
>The other fellows are right, but there's another catch:
Sliding rate scales according to use in the billing period. In our area, with certain use patterns, we can, and have this summer, gotten to kwh charges approaching $0.45, or 5 times your posted rate. Ouch.
Sawman
>Thanks!!
$.45/KWH? Yikes!
Dan Mitchell
>We live in the Seattle area, where much of the power is hydro. From our local utility's web site: "As of July 1, 2009, residential rates are about 8.0 cents per kilowatt-hour for summer usage and 8.4 cents per kilowatt-hour for winter usage." Do you happen to know how the power is generated in your area?
Lance Armstrong peddling generator.
Alexander Grigoriev
>A bit of nit-picking.
kW/h would mean "kilowatt per hour" which doesn't make sense.
kWh, which means kilowatts-hours, kilowatts times hours.
Re: $.45/KWH? Yikes!
>It's a blend of sources. Hydro, nuclear, NG, wind, solar, biomass, whatever.
The cost factor problem is that we're into the 300% screw them range of power consumption. It's a remnant of the 2000 era power experiment that California went through, when we got Enron-ed...
The point is that you can't just figure based on the baseline per kwh cost. Solar generation at home looks a lot better here if you're clipping the peak rate generated highs off of your bill.
Bill Wilkinson
>Don't forget your physics when you price the electricity usage for the shop.
All (almost)energy eventually becomes heat.
Thus electricty used to run your machinery eventually heats the shop, reducing the need for heat from the principal source, like furnaces or whatever, for the shop.
Thus the use of the shop machines during the heating season effectively costs nothing.
Here in Quebec, we heat our houses with electric resistance elements (the electricity costs in the area of 0.052 per kwh, well below oil or gas.) Thus our use of any electricity eventually becomes heat inside the house (in the winter). - Our computers, incandescent light bulbs, televisions, stoves, ovens, water heater, etc, effectively produce heat as efficiently as the resistance element in the furnace. If we are heating anyways, they cost nothing to operate.
We had an engineering eval for a ground-source heat pump a few years ago, and it could only save on the heat produced by the furnace, not that produced by the lighting, appliances, etc. I was quite surprised that these other sources added up to about 35% of the heating in the home. In milder climates, the percentage is larger.
As you may guess, I believe the emperor has no clothes concerning CFL's.
The other side of the coin, is in the summer, if we are using air-conditioning, those appliances cost DOUBLE. (Incandescent bulbs too)
We pay once for the energy to run the device, and again to pump the heat outdoors.
Cap and Trade
Jerry Nicholson
>Just wait until the cost of the so-called "cap and trade" hits us. $0.45 per kwh might seem like a real bargain in 5 years or so.
Jerry
Victor Parisian
>Been trying to explain that to my wife for many years now.
"We Pay for it once to cook our dinner (run the TV burn a light etc) and again to run the a/c to remove the heat."
Victor - working hard to support the electron habit...
