OT, kinda: bathroom cabinet stock
>So, we're getting ready to tackle the second bathroom, which I badly remodeled some years back. Space constraints are such that we'll be building our own cabinet, to maximize space use. One module of the cabinet will be full height (well - probably resting on a 2x4 base, probably some kind of crown molding - but almost full height). Cabinet will be painted.
The room has an 8'8" ceiling, and I don't plan to use up 8 inches with the base and crown, so I'll be looking for 9-10 foot plywood. The good local home improvement center gives me conflicting advice: one of the staff says "birch ply, but go to the contractor's desk to see if you can get longer than 8 feet." The buyer at the contractor's desk says, "You can't use birch ply in a bathroom cabinet."
Advice?
Re: OT, kinda: bathroom cabinet stock
Thomas S Stockton------WebKitFormBoundaryRU4sWQOIA
>Bill,
Mt Storm in Windsor is your friend. Give them a call they will tell you what plywood they carry in ten foot lengths.
If I were building something that tall I would probably try and figure out how to make it in two pieces or drop the height so it isn't so tall.
Tom
>Find a different "contracts' desk." Birch is just fine in a bathroom so long as it (like any other ply) is properly sealed.
To help narrow your search, look for a "fabricator's supply" in your area. These are guys who supply the cabinet trade with with both oversize ply, HD fiber, and HP laminates. That'll likely be your best bet for oversize ply unless you have a manufacturer in your area.
Good Luck.
Fred Davis
>A easy way around this height problem is a soffit over the cabinet that would look good with or without a crown on it.
Then there is always solid stock.
FredD
Glenn Madsen near San Francisco
>I made some cabinets for the bathroom at 8' or thereabouts, right near the ceiling height. And had to redo them because I couldn't tip them into place. ARrrghhghhgh!!
Think two pieces. Also think pro supplier for materials. I use Plywood and Lumber Sales in Oakland, but the suggestion for Mount Storm in Windsor is a lot closer to you. Be aware that they used not to take plastic, so bring your checkbook...
My choice is a domestic maple ply, prefinished. Columbia, IIRC. Never tried to buy 10' though. My mid-70's 'mansion' has the lower ceilings.
Re: OT, kinda: bathroom cabinet stock------WebKitF
Hamish
>Morning Bill,
I'm not sure what your bathroom is like but I wondered if you had thought about lowering the ceiling or fitting a suspended criss-cross lattice of wood to disguise the height of the room. It seems to me from what you have said, that making such a tall cupboard, will necessitate a small step ladder or chair to access the upper shelves. Lowering the cupboard would also take away the problem of obtaining suitable stock.
Just a thought, regards Hamish.
