OT: Gentlemen, get to know your PSA value...
Jesper, Denmark
Jesper, Denmark
>No, this has nothing to do with Pressure Sensitive Adhesive, but your Prostata Specific Antigen.
I will undergo surgery for Prostata Cancer in a week. It was discovered "Incidentally" as part of a standard blood screen recently. Prognosis at this point is good for a cure.
The point is that I have no symptoms and if it had been left undiscovered just a little longer, the prognosis could be very different.
I thought a lot of whether this messages was appropriate. It is not a sob story, but a reminder that all mature men are in the risk group for this disease. As I perceive that there is a preponderance of mature males in this forum, it seemd an appropriate reminder.
Prostate Cancer is the most common cancer in men. If discovered in time, it can be cured. The PSA test is very simple and cheap.
Disclaimer: I have no medical qualifications and there is some controversy in the medical community. You can easily Google yourselves to a lot of information from well qualified sources.
Re: OT: Gentlemen, get to know your PSA value...
Thanks, Jesper...
>... and good luck with your surgery. A close friend recently underwent a similar surgery and caught the disease in time. Others haven't been so lucky. I get blood work annually. Hopefully that is often enough.
Re: Thanks, Jesper...
ehgauss
>Yea and verily on that. I had been watching my PSA in my annual physicals for years as it crept slowly upward with age. Just two years ago, there was a sharp jump, and my physician sent me to a urologist for followup. Bottom line, there was a tumor. I was apparently not a candidate for surgery, so I went first into hormone treatment to stop the growth of the tumor, then nine weeks of radiation therapy three days a week. I've had three successive semi-annual satisfactory examinations now, and the radiation oncologist says that I will not die of prostate cancer. Advice to everyone over about 40: GET YOUR PSA CHECKED AT LEAST ANNUALLY AND UNDERSTAND WHAT IT MEANS!!
Thanks for the reminder..
Thanks and best of luck !
Don Orr
>I'm overdue myself. Turned 50 this year. Have a cousin who had his prostate removed in his early 40's.
Yes, indeed
>I had a prostatectomy* January 20, and the evidence is that I'm now cancer-free (two follow ups at zero PSA). My doctor caught it from a subtle change in my PSA level and an equally subtle change in the texture of my prostate during that not-very-comfortable digital exam.
There are a lot of confusing research results, but mine was caught before the tumor had broken through the prostate wall - so the likelihood is that it was all excised, and I don't feel at all controversial about THAT.
I'll be happy to share my experience and thoughts with you (or others).
*Technically, it's a "radical prostatectomy," although, since the organ is about the size of a walnut, I'm not sure what a less-than-radical one would look like. Very fine slicing to remove half of it...
Paul Blackwell
>I was diagnosed with prostate cancer six years ago. I researched several methods of treatment on the internet, and came across one done by Radiotherapy Clinics of Georgia. It uses radioactive seed implants followed by radiation therapy. I attended support group meetings and spoke to many men who had the treatment done in Atlanta, and they were universal in their praise. After meeting with the head of the clinic, I decided to go there. They have treated well over 10,000 men from all over the world, with a higher cure rate than any other method of treatment. You must get the treatment in Atlanta, but of the six weeks stay for radiation, I stayed at the Hope Lodge for free. I urge anyone facing treatment to at least research this method. My PSA has consistantly tested <0.2 for 5 1/2 years now. Their website is www.rcog.com.
Lots of roads up the mountain
>and lots of prostate cancer treatments. Yes, research, and take the best available choice - as best you can understand it.
Like other cancers, prostate cancer gets found at multiple points in its development, and the variations seem to mean that no one treatment works for all.
Once A Year
>Blood test.
Unfortunately, the PSA test ain't as accurate as most think it is, but it's way better than not testing.
Since my grandfather died of it and my father was treated (seeds), I'm naturally vigilant.
Joseph Mulherin, Sr
>I go to my VA clinic here in Palm Desert, CA and have blood draws every three months. The tests for all diseases can be determined pretty much from these draw tests.
As regards prostate cancers and operations for removal.... When they do most of the surgeries you will end up impotent.... which is it seems to be the end our our men's lives... BUT there is another surgery available which does not cause this....it is CRYO-ABLATION.
Basically, it is injection of liquid nitrogen directly into the tumor. which instantly freezes the tumor and its blood supply for feeding and kills it almost instantly. Then the bodys normal immune system takes over and dissolves the tumor...and you are still potent to have sex. Talk to your doctors about this treatment.
Joseph Mulherin, Sr
>Follow-up: go to this website for more information: www,endocare.website.com or Google and find out info on this method of surgery for the prostate cancers. There is also a video available which show exactly how the procedure is performed.
I'm a poster boy for the Flo-Max ads
Forrest Addy
>I'm a poster boy for the Flo-Max ads you see on TV. I have major BPH and the PSA screen has been part of my annual check up for many years. So far so good and let it stay that way.
If you're over 45 better get a PSA test if only to estalish a baseline even if your Dr hasn't seen fit to check you. Ounce of prevention...
Some details
Al Goldstein
>Sign up for the Johns Hopkins Medical Alerts newsletters at johnshopkins@e.johnshopkinshealthalerts.com
Lots of good information concerning prostate health and PSA tests. For example, no sex the night before the blood draw and the most aggressive forms of prostate cancer occur in young men under 60. So PSA testing should not be postponed.
A little bit of education goes a long way.
Good luck to all.
I dodged a bullet
Neal in San Jose
>Back in May my annual physical showed a spike in my PSA. It had been creeping up, but spiked to 7 from 4.5 in a year. I was scheduled for a biopsy and have to say that was the longest month's wait I've ever experienced. Result: no cancer, just normal age related prostate issues. Personally, I'd MUCH rather have a false positive on the PSA and do the biopsy than miss it and cash in my chips early.
The good news and related relief those test results brought was worth a million bucks. I broke out a bottle of wine I'd been saving for a special occasion. I figured it didn't get any more special.
Bottom line: Get it done, guys. This is something you must stay on top of.
Thanks, Jesper, and good luck.
Be wary
paul in AZ------WebKitFormBoundary+isMX5X2paiDYC5e
>While the PSA is the only useful test available to date it is not as accurate as originally hoped.
My PSA was in the mid normal range for years when a competent examiner found a malignant nodule. I am now 3 years post external radiation [IMRT] and clinically and chemically tumor free with a PSA well below 1.
A normal blood test does not exclude cancer just as elevated levels can result from sex; inflammation; BPH and advancing age.
A clinical exam by a capable examiner is always worth doing on an annual basis.
PSA
>PSA measures the "activity" level of the prostate, as I understand it. As someone else mentioned, sex right before a PSA test can elevate it, as can infection or anything else that would inflame the prostate or increase its activity level.
Thus, prior to prostate removal, it's mainly useful as an indicator that attention must be paid. The digital rectal exam, as uncomfortable as it is (though I suspect no more uncomfortable than what women experience in their annual exams), is another useful indicator, if the physician is good (mine caught what the specialists tell me was a very subtle texture change; that, and slightly elevated PSAs, were what got me started).
Biopsy is a reliable test, but expensive and thus not done except when indicated. It also puts the digital rectal exam in perspective.
biopsy
>Thanks. I forgot to mention that biopsy is the next step if there is any indication. Biopsy is the diagnostic gold standard and not only makes the Dx but grades the aggressiveness and extent of any cancer found. The Gleason score derived from the biopsy is used as a factor in determining therapy. [I used to read these biopsies]
The procedure is done with a needle, in the office, sampling both lobes, and the only discomfort or 'complication' is usually no more than peeing pink from a few blood cells for a day or so.
Blood test for PSA value...
Bricofleur
>Thanks Jesper,
I'm waiting for the results from the blood test I had last week. My physician felt a cyst on my prostate on my annual check-up and he sent me to an urologist for further investigation. This specialist didn't feel anything but he sent me for a blood test and urine test to be sure.
Over 50 each and every man should have at least a physical examination (the finger) from his physician.
By the way, last Winter I was watching a lecture from doctor I can't remember the name on PBS. The doctor mentioned that few doctors make the prostate test with two fingers. He said they want a second opinion!!! Every participants were up for a good laughter. I told this one to my own physician and he thought it was a good one too!!!
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Bill White
>Jesper is on the money. I caught the uptick in the PSA readings in time. Told the doc to jerk that sucker out. I'm not man enough to face cancer. Don't regret it at all. Now if I could just get my back to work right..........
Bill
Jim Dillon
>Jesper,
Good luck with your surgery and we all hope the best for you! I returned to my regular doctor over a year ago after an absence of 10 years. My PSA test turned out fine (thank goodness, as my father died of prostate cancer), and has remained low. My doctor breathed a sigh of relief as he had had a patient in the week before, who had also been absent for 10 years, and the results were not good. While I understand the PSA test has diagnostic issues (high false positives, somewhat high false negatives), it is important to establish a trend for your own body. My only complaint is that sometimes I get a feeling that my physician enjoys doing the manual exam just a little too much 8-)8-).
Jim
Joseph Mulherin, Sr
>Further follow-up: go to this website to see the video showing the procedure: http://www.ocurology.com/prostatecancer.html
Jesper, Denmark
PSA update........
Jesper, Denmark
>Thanks for all your expressions of concern and sympathy.
Today i received the final good news that the cancer had been completely contained ( A T2c for the technically interested) and had been completely removed. There was no involvement in the lymph nodes, which were excised.
The result is a compete cure, but testing every three months for a year to be sure.
In my case, the expected side effect of incontinence did not happen at all, so after another four weeks of restricted physical activity to ensure that the various cuts and re-connectons are fully healed, I should be back to full vigor.
One last reminder: If you are in the risk group, please get your PSA value checked and act on it. Early detection does save your life. The most recent USA analysis of the value of PSA screening is seriously flawed. If you need references to a qualified discussion on the�, feel free to send me an e-mail.
Good news..
>in all aspects. Depends are a PITA.
Great...
>Always good to hear good news.
I am now 3+ years post external [IMRT] radiation and am clinically just fine with a PSA of 0.5.
My PSA had never been out of the mid portion of the normal range. I can testify that relying on the PSA alone would not have picked mine up.
Don't forget to get the big finger test guys.
