OT Cornerbead for Drywall
howard
>I am building a room that has several outside corners that are not at 45 degrees. Should cornerbead be used on these corners, or just mud and tape? Appreciate your help.
thanks
howard
thanks
Re: OT Cornerbead for Drywall
Jon Weisenbach
>Howard....
If you go to either a DW supply or perhaps a local lumber yard there is a product called "Flexbead" which is a flexible corner bead that has metal or now perhaps plastic bands that are on the underside of the tape. You mud the tape on the corner then finish as needed to have a finished corner that will take a much stronget degree of punishment than just a paper taped corner!
Jon
Bill White
>You don't EVEN wanna go without a corner bead. You'll have "corner smash" all too soon without it.
Bill
>I concur with Jon and Bill: always use a corner bead. I tried it without in some early projects and, in addition to a weaker corner, you'd find it VERY hard to do a good clean, un-lumpy job. The corner bead gives you a line against which to work.
